Dropdown widget color dynamically as per selection of value
H_1234
11-Garnet
In one of my application we have to apply color or border color of dropdown widget dynamically as per selection of value. We are able to set the dropdown list color but not be able to fill the complete widget color based on the selected option.
Please suggest how to create state defination to set the drop down widget color.
Best Regards
Hareef,
bchaudhary
(To:H_1234)
Hello @H_1234 ,
pls check the following article which contains to change the appearance of the drop down widget:
https://www.ptc.com/en/support/article/cs324593
https://www.ptc.com/en/support/article/cs322901
pls let me know if you have any further queries.
Bhawna
bchaudhary
(To:H_1234)
Hello @H_1234 ,
Bhawna
Hi Bhawna,
Thank you for your Suggestion
We want to change Dropdown border colors as per selected value
Eg: if value is High-->Border color  red
      if value is low -->Border color  green
