Dropdown widget
AC_9552412
Dropdown widget
Hi, how can you clear the selected data from a dropdown with an external button?
3 REPLIES 3
yhan
(To:AC_9552412)
Hi @AC_9552412,
You can try:
1. Bind external button event/service to SetGlobalSessionBooleanValue
2. Bind the parameter value from GetGlobalSessionValue to ClearSelectionItem of the drop-down widget
so that when the user clicks the button, it can pass the clear selection command to the drop-down widget.
/Yoyo
AC_9552412
(To:yhan)
Hi, @yhan
the option to clearSelectionItem is only allowed if the dropdown is not multiselection, how can it be done with a multiselection?
yhan
(To:AC_9552412)
Hi @AC_9552412,
Please check if PTC article CS337514  can achieve your business needs.
/Yoyo
