Dynamic Programming Challenge: Longest Increasing Subsequence
sachinbhatt
8-Gravel
Given an array of integers, find the length of the longest increasing subsequence. A subsequence is a sequence that can be derived from another sequence by deleting some or no elements without changing the order of the remaining elements.
For example:
#include <iostream>
#include <vector>
int longestIncreasingSubsequence(const std::vector<int>& nums) {
    // Your dynamic programming solution goes here.
    // Return the length of the longest increasing subsequence.
int main() {
    std::vector<int> sequence = {10, 22, 9, 33, 21, 50, 41, 60, 80};
    int result = longestIncreasingSubsequence(sequence);
    std::cout << "Length of the longest increasing subsequence: " << result << std::endl;
    return 0;
I'm specifically interested in implementing this using dynamic programming techniques. How can I approach this problem using dynamic programming, and what would be the C++ code for solving it? Any insights, code snippets, or explanations would be incredibly helpful in mastering dynamic programming for this particular challenge. Thank you for your assistance!
1 REPLY 1
FYI: You did post your question in a ThingWorx section/forum which cannot help you with your query
