Dynamic Thing Template to Line chart Widget
VC_10938534
I'm using ThingWorx 9.3.5
I've been trying to link a Dynamic Thing Template to a Line Chart Widget and have been quite unsuccessful. I was wondering if there is possibility that I could use Dynamic Thing Templating to pull Data and push into a line chart. If so, could anyone possibly help me with that?
@VC_10938534  So, you are using a service or Property (infotable) for the data ?Either case, if you have a thing based on the TT and pass the ThingName to the TT in Mashup, It should work.
Hi @VC_10938534
Could you please share some screenshot to under your issue better
/VR
