I have a Mashup having SMTP configuration fields which will take as a input from the user. On saving this configuration I need to dynamically create a thing of Base type "MailServer" with the user given configuration through ThingWorx service. Kindly assist with the steps.
Below are the configuration fields in the Mashup
SMTP Server
SMTP Port
User Name
Password
SSL
Hi @SKannapiran ,
For validating configuration of SMTP user feed, need to send a demo mail to some user then only we can find. In 2 ways we achieve it.
Kindly select the case based on your requirement. Kindly find the 2nd way updated code in below.
try {
if (IP_Server == null || IP_Server == undefined || IP_Server == "" || IP_Server == "undefined") {
throw {
"message": "Please Enter Value for Server"
if (IP_PortNumber == null || IP_PortNumber == undefined || IP_PortNumber == "" || IP_PortNumber == "undefined") {
throw {
"message": "Please Enter Value for Port Number"
if (IP_Email == null || IP_Email == undefined || IP_Email == "" || IP_Email == "undefined") {
throw {
"message": "Please Enter Value for Email"
} else {
var email = '';
function isValidEmail(email) {
var emailRegex = /^[A-Za-z0-9._%-]+@[A-Za-z0-9.-]+\.[A-Za-z]{2,4}$/;
return emailRegex.test(email);
if (isValidEmail(IP_Email)) {
IP_Email = IP_Email;
} else {
throw {
"message": "Please Enter Vaild Email Address"
if (IP_Password == null || IP_Password == undefined || IP_Password == "" || IP_Password == "undefined") {
throw {
"message": "Please Enter Value for Password"
let emailThingName = "PTCCommunity.Email.TH";
// Create a thing with Unique entity name based on Templete of MailServer
try {
let params2 = {
name: emailThingName /* STRING */ ,
description: undefined /* STRING */ ,
thingTemplateName: "MailServer" /* THINGTEMPLATENAME */ ,
projectName: "PTCDefaultProject" /* PROJECTNAME */ ,
tags: "PTC:DEMO" /* TAGS */
// no return
Resources["EntityServices"].CreateThing(params2);
// Enable the new thing for updating the configuration
Things[emailThingName].EnableThing();
// Encrypt the Password from String Input
let params1 = {
data: IP_Password /* STRING */
let encryptPassword = Resources["EncryptionServices"].EncryptPropertyValue(params1);
// Get Configuration infotable from new email server thing
let connectionInfoConfig = Things[emailThingName].GetConfigurationTable({
tableName: "ConnectionInfo" /* STRING */
// Update the configuration info based on user input
connectionInfoConfig.smtpServer = IP_Server; // SMTP Server - STRING
connectionInfoConfig.smtpPort = IP_PortNumber; // SMTP Server Port - NUMBER
connectionInfoConfig.accountId = IP_Email; // Mail Account User - STRING
connectionInfoConfig.accountPassword = encryptPassword; // Mail Account Password - STRING
connectionInfoConfig.useSSL = IP_SSL; // SSL - BOOLEAN
connectionInfoConfig.useTLS = IP_TLS; // TLS - BOOLEAN
// Update the created mail thing configuration table
Things[emailThingName].SetConfigurationTable({
configurationTable: connectionInfoConfig /* INFOTABLE */ ,
persistent: true /* BOOLEAN {"defaultValue":true} */ ,
// Finally restart the newly created thing
Things[emailThingName].RestartThing();
} catch (e) {
throw {
"message": "Entity is already Created!!"
try {
// Send demo mail for the validation
Things[emailThingName].SendMessageWithNoReplyTo({
subject: 'Demo Mail Setup' /* STRING */ ,
to: "demomailuser@gmail.com" /* STRING */ ,
body: '<p>Hi,</p><p>This mail is triggerd for SMTP Configuration Validation. Kindly ingore this mail.</p><p>Thanks.</p>' /* HTML */
result = "Email thing was created and configured successfully!";
} catch (e) {
// If demo email is fail delete the entity
let params = {
name: emailThingName /* THINGNAME */
Resources["EntityServices"].DeleteThing(params);
// Validation Message
throw {
"message": "Issue in SMTP configuration Kindly Validate it!"
} catch (e) {
result = e.message;
Thanks & Regards,
Arun C
Hi @SKannapiran ,
Kindly find the below code for creating & configuring mail server thing with SMTP setup. It will hepls you.
// Declare or Create the unique name for entity(thing) creation
// Validate the inputs based on the requirement
try {
throw {
throw {
throw {
throw {
try {
// Create a thing with unique entity name based on Thing Templete of MailServer
let params = {
Resources["EntityServices"].CreateThing(params);
let params1 = {
// Update configuration table in newly created mail thing
} catch (e) {
throw {
"message": "Email thing was already craeted / Issue in configuration!"
} catch (e) {
result = e.message;
If any queries kindly let me know.
Thanks & Regards,
Arun C
Hi @Arun_C ,
Thanks a lot for sharing your code, the above code works fine.
In addition, there is a need to validate user-fed SMTP configurations before creating a dynamic mail server.
This validation has to be performed within the ThingWorx script itself.
The dynamic mail server thing can be created upon successful validation.
Could you please share code snippet for the same. Thanks in advance.
Hi @SKannapiran ,
try {
throw {
throw {
throw {
} else {
var email = '';
} else {
throw {
throw {
try {
let params2 = {
// no return
let params1 = {
} catch (e) {
throw {
try {
} catch (e) {
let params = {
throw {
} catch (e) {
result = e.message;
Thanks & Regards,
Arun C
