Hey,
I try to evaluate the possibilities of the EMS Stuff. Today I try the file transfer functionality with no success.
I have a device where the ems runs on (as gateway) and a twx instance on a ec2 in aws.
My config.json lookes like this:
"ws_servers": [{
"host": "xxx.xxx.xxx.xxx", (TWX IP)
"port": 443
"appKey": "xxxxxxxxxxxxxxxxx",
"logger": {
"level": "INFO",
"publish_directory": "/microserver/logs",
"publish_level": "INFO",
"max_file_storage": 2000000,
"auto_flush": true
"http_server": {
"host": "xxx.xxx.xxx.xxx", (IP EMS runs on)
"port": 8000,
"ssl": false,
"authenticate": false
"ws_connection": {
"encryption": "ssl"
"certificates": {
"validate": false
"tunnel": {
"buffer_size": 8192,
"read_timeout": 10,
"idle_timeout": 300000,
"max_concurrent": 4
"file": {
"max_file_size": 8000000000,
"virtual_dirs": [
{"other": "/microserver/other"},
{"tw": "/microserver/tw"},
{"updates": "/microserver/updates"}
"staging_dir": "/microserver/staging"
"auto_bind": [{
"name": "EMSGatewayThing",
"gateway": true
"name": "OtherEdgeThing",
"host": "1.0.1.2",
"port": "8001",
"protokol": "http",
"gateway" : false
My lua-script looks like this:
scripts.log_level = "WARN"
scripts.script_resource_ssl = false
scripts.script_resource_authenticate = false
scripts.EdgeThing = {
file = "thing.lua",
template = "YourEdgeThingTemplate",
scanRate = 120000,
sw_update_dir = "/microserver/updates"
I try to send a small simple txt-file from SystemRepositoy to the "other"-folder on the edge device via the copy-service of the FileTransferSubsystem.
After the timeout-time ends I get a result table with not much information what went wrong. In Application Log i get this:
[context: Error occurred during transfer.: service execution failure resultCode=STATUS_GATEWAY_TIMEOUT: job=TransferJob [tid: adf44aaa-df36-463d-88d3-3f5d1d066e62, sourceRepo: SystemRepository, sourcePath: /file-transfer-test.txt, targetRepo: OtherEdgeThing, targetPath: other/file-transfer-test.txt, partPath: __staging__/OtherEdgeThingother.file-transfer-test.txt.part, sourceChecksum: , targetChecksum: , state: ACTIVE, code: 202, message: Transfer request accepted, isAsync: false, isRestartEnabled: true, isComplete: false, bytesTransferred: 0, blockcount: 0, blocksize: 8192, size: 35, maxsize: 100000000, transferTime: 0, transferControl: platform, reservationId: , user: david.richter, isQueueable: false, enqueueTime: 0, enqueueCount: 0, metadata: null, Job [id: adf44aaa-df36-463d-88d3-3f5d1d066e62, lastTouch: 1574415465008, timeout: 30000, TimedLock [createTime: 1574415464898, signalTime: 0, duration: 0, signaled: false]]]]
This says the transfer request was accepted (202) but no data was transfered.
On my edge device a I have a new created .part file (OtherEdgeThingother.file-transfer-test.txt.part) with size of zero.
I have no idea what went wrong. Both devices (EMSGatewayThing and the OtherEdgeThing) are connected under remote things
Hi @drichter
Can you please add the host and port used by the http_server configuration to auto_bind configuration?
Following article refers the resolution and provides a sample config.json that can be referred
URL: https://www.ptc.com/en/support/article?n=CS304858
Please do let us know if this helped resolve the issue.
Nisha Nair
Hi @nishanair,
I add the host and port to the first element of the auto binding group, with the same ip and port like in http_server but I get the same error.
If you couldn't solve the problem try these changings.
"http_server": {
"host": localhost or 127.0.0.1,
"port": 8080,
"ssl": false,
"auto_bind": [{
"name": "name of your thing",
"port": 8080
Hi @drichter.
Have you found a solution to your problem? If so, please post it here and mark it as the Accepted Solution or mark an existing reply.
Regards.
--Sharon
