I am trying to run the AddEdgeThing remote service through the composer. The serivice comes from my EMSGateway thing that I have bound in my TWX instance.
The problem I have is I do not know what input/outpus it needs. When you import the remote service it does not import inputs and outputs.
In the EMS documentation you can find some information about it but it does not state clearly what types the parameters should be.
So far I've tried passing a JSON object, an INFOTABLE containing JSON objects and few others. The result I get is always similar to this:
In addition running a service with incorrect parameters shuts down my EMS.
Any idea what should the input/output parameter types be?
