I'm testing some EMSs (one on my pc and some on GW devices) and every invocation of service getLogData returns me an empty infotable.
Of course the EMSs are logging on console and file.
I can't find anykind of configuration needed to read the logs via service.
Why it happens?
Hi @draskar.
If we're understanding correctly, this issue has been resolved in EMS 5.4.7. Which version are you running?
Regards.
--Sharon
I'm currently using 5.46 version.
I'll download the new version and let you know but I'm a bit skeptical: getLogData never worked in previous versions? It seems strange.
in my download section I can only find this version:
Microserver-Windows-x86-32-openssl-5-4-0-114 (3 MB)
why 5.4.0?
I've downloaded the new version but it doesn't work anyway.
I didn't receive a NULL response but, instead, the EMS simply crushes.
Hi @draskar.
EMS 5.4.8 is releasing today and should contain a fix for your issue. Please test it out and let us know if your issue is resolved.
Regards.
--Sharon
Hi @draskar.
Please let us know if you've had a chance to test out EMS 5.4.8 for resolving your issue.
Regards.
--Sharon
I'm only able to download 5.4.0 version.
It's the second time I have this issue.
Can you please fix my user account?
Hi @draskar.
You should be able to find the latest release by following these instructions:
Please let me know if you have issues.
Regards.
--Sharon
yes I'm totally aware of how to dawnload it.
But this is the second time I have the issue.
When you upgrade the EMS version, in dowload section only appears the 5.4.0 version, not the latest one.
Happened the same when you released the 5.4.7 version and I had to open a ticket to fix my account.
Can you please fix it without opening another ticket?
Hi @draskar.
Please send me a private email with the email you're logging in with and a screenshot of what you're seeing, so we can follow up.
Regards.
--Sharon
problem is now solved.
I was able to download the version MED-61060-CD-054_SP8_Microserver-Windows-x86-32-openssl-5-4-8-1055
Last time I tried (24 april) I was only able to donwload this version:
MED-61060-CD-054_F000_Microserver-Windows-x86-32-openssl-5-4-0-114
Hi @draskar.
If this issue occurs in the future, please try with a different browser or clear your cache. If the problem persists after doing so, please provide the needed information so we can investigate.
Regards.
--Sharon
i'm trying the new EMS version but now I'm not able to connect anymore (in both DEV or PROD)
Config file is the same so I'm sure that everything is set ok:
[ERROR] 2020-05-06 09:45:12,471 SDK: twWs_Connect: Error restarting socket. Error 0
[DEBUG] 2020-05-06 09:45:17,472 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2020-05-06 09:45:17,472 SDK: twTlsClient_ConnectSession: Connecting to server
[ERROR] 2020-05-06 09:45:17,516 SDK: TW_NEW_SSL_CLIENT: SSL handshake error. Error: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed.
Have this new version some SSL restriction?
I also tried to connect without SSL ("encryption": "none" on config.JSON and http port changed)
Another error:
[DEBUG] 2020-05-06 10:13:30,390 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2020-05-06 10:13:30,390 SDK: twTlsClient_ConnectSession: Connecting to server
[ERROR] 2020-05-06 10:13:30,433 SDK: twWs_Connect: Error reading from socket. Error: 10054
I also noticed that now EMS encrypt by itself the appKey.
Can I have a changelog of this version?
Ok some security checks but I can't understand how to make this EMS work (at least without SSL).
Can you help me?
Hi
Please take a look at the Help Center to verify your configuration. If you're not able to resolve the issue, check the section on Information to Provide When Reporting an Issue and provide the needed information. It may be necessary to open a case for investigating further.
Regards.
--Sharon
the "version issue" happened again.
I tried with Chrome in "incognito" mode but the issue remain.
I Opened case 15599759
Hi @draskar.
I checked the case but see that it was closed since the issue disappeared. Now that you have been able to download the needed EMS version, did it resolve your issue?
Regards.
--Sharon
Hi @draskar.
Please let us know if you are still having issues. If so, I will be happy to open a case on your behalf. We will need the details per this Help Center topic.
If you have now resolved the issue, please provide the solution for the benefit of others on the community.
Thank you for your participation in our Community!
Regards.
--Sharon
Hi, with the latest version it works,
but all timestamps are dated 1970.
Have you noticed that before?
Hi @draskar.
Is it possible your system date is wrong? Or possibly something wrong with your conversion? We're not seeing the problem in our testing.
In regard to the issue of the latest releases not showing up on the support site, are you selecting the "Order or Download Software Updates?" If you choose the "Download Software by Sales Order Number" option, it will only show the version indicated in your Sales Order.
Regards.
--Sharon
I tried again with the windows EMS installed on my PC and it works.
So I tryed again the GW (with Linux EMS) on the same enviroment and now it desn't return logs at all (see attachment).
It's on since yesterday and of course he is logging on file (with 777 permissions)
Hi @draskar.
Which flavor of Linux are you running? Which download file did you use? Can you clarify regarding the logs? Are you seeing logs being generated?
Regards.
--Sharon
We have installed it on a Gateway with Debian.
The first time we tried we had the "1970 issue" described before .
The second time (after I tested successfully this version on my windows pc) non logs was returned to the API (empty infotable).
EMS logs on file without problems
Hi @draskar.
Do the logs have the correct date now? Since you switched operating systems, did you confirm you're using the latest version of the EMS?
If you still have issues, I suggest we open a case for your issue. I will be happy to open one on your behalf, if you agree.
Regards.
--Sharon
Sorry I'm clearly not able to let you understand.
My issue is still presente with the "Linux version".
I did the same test with the windows version and it works (only to be sure that I was doing the right steps).
Can you please test this feature with the latest "linux version" on one of your devices?
Hi @draskar.
You will need a case for this issue. I will be happy to open one on your behalf with your approval.
Regards.
--Sharon
Thanks a lot.
Please open a ticket and find together a calendar slot for a webEx.
I'm ready to test the Debian EMS now.
