18-Opal
March 3, 2025
ERROR: canceling statement due to user request
  • March 3, 2025
  • 2 replies
  • 988 views
I have recently upgraded from Thingworx 9.1 to 9.7. The DB also got upgraded.
I did a dump of the DB and restored it to my local environment, and the instance is working fine. But when I do a restore, it does not work fine in the QA Environment.
Below is the Error I get in the logs:
2025-02-28 11:04:13.242+0000 [L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: Bindhu] [S: ] [P: ] [T: http-nio-8080-exec-9] Unable to Invoke Service QueryNamedPropertyHistory on Postman_Thing : com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.] org.postgresql.util.PSQLException: ERROR: canceling statement due to user request
	at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2676)
	at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2366)
	at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:356)
	at org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:496)
	at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:413)
	at org.postgresql.jdbc.PgPreparedStatement.executeWithFlags(PgPreparedStatement.java:190)
	at org.postgresql.jdbc.PgPreparedStatement.executeQuery(PgPreparedStatement.java:134)
	at com.mchange.v2.c3p0.impl.NewProxyPreparedStatement.executeQuery(NewProxyPreparedStatement.java:431)
	at com.thingworx.persistence.common.SQLStatementUtilities.executeQuery(SQLStatementUtilities.java:107)
	at com.thingworx.persistence.postgres.dao.BasePostgresDao.executeQuery(BasePostgresDao.java:137)
	... 78 common frames omitted
Wrapped by: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
	at com.thingworx.persistence.postgres.PostgresDataExceptionTranslator.rethrowTranslated(PostgresDataExceptionTranslator.java:48)
	at com.thingworx.persistence.postgres.dao.BasePostgresDao.executeQuery(BasePostgresDao.java:139)
	at com.thingworx.persistence.postgres.dao.PostgresValueStreamDao.getMultiPropertyIterator(PostgresValueStreamDao.java:351)
	at com.thingworx.persistence.postgres.dao.PostgresValueStreamDao.getMultiPropertyEntries(PostgresValueStreamDao.java:308)
	at com.thingworx.persistence.postgres.dataprovider.PostgresValueStreamDataProvider.getMultiPropertyStreamEntries(PostgresValueStreamDataProvider.java:560)
	at com.thingworx.persistence.postgres.dataprovider.PostgresValueStreamDataProvider.processMultipropertyNotLazy(PostgresValueStreamDataProvider.java:370)
	at com.thingworx.persistence.postgres.dataprovider.PostgresValueStreamDataProvider.queryMultiPropertyValueCollections(PostgresValueStreamDataProvider.java:478)
	at com.thingworx.persistence.common.ValueStreamEngine.lambda$queryMultiPropertyEntries$12(ValueStreamEngine.java:362)
	... 72 common frames omitted
Wrapped by: java.lang.RuntimeException: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
	at com.thingworx.persistence.common.ValueStreamEngine.lambda$queryMultiPropertyEntries$12(ValueStreamEngine.java:391)
	at com.thingworx.persistence.TransactionFactory.supplyInTransaction(TransactionFactory.java:187)
	at com.thingworx.persistence.TransactionFactory.createEagerDataTransactionAndReturn(TransactionFactory.java:161)
	at com.thingworx.persistence.common.BaseEngine.createEagerTransactionAndReturn(BaseEngine.java:199)
	at com.thingworx.persistence.common.ValueStreamEngine.queryMultiPropertyEntries(ValueStreamEngine.java:354)
	at com.thingworx.valuestreams.ValueStreamThing.queryMultiPropertyStreamEntries(ValueStreamThing.java:340)
	at com.thingworx.things.Thing.doQueryPropertyHistoryLocal(Thing.java:11856)
	at com.thingworx.things.Thing.doQueryPropertyHistory(Thing.java:11805)
	at com.thingworx.things.Thing.QueryNamedPropertyHistory(Thing.java:9785)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:566)
	at com.thingworx.common.processors.ReflectionProcessor.processService(ReflectionProcessor.java:232)
	at com.thingworx.handlers.ReflectionServiceHandler.processService(ReflectionServiceHandler.java:54)
	at com.thingworx.handlers.ServiceHandlerBase.processServiceWithMetrics(ServiceHandlerBase.java:62)
	at com.thingworx.things.Thing.executeServiceWithServiceHandler(Thing.java:9074)
	at com.thingworx.things.Thing.processServiceRequestDirect(Thing.java:9053)
	at com.thingworx.things.Thing.processAPIServiceRequest(Thing.java:9027)
	at com.thingworx.webservices.BaseService.handleInvoke(BaseService.java:3430)
	... 53 common frames omitted
Wrapped by: com.thingworx.common.exceptions.InvalidRequestException: Unable to Invoke Service QueryNamedPropertyHistory on Postman_Thing : com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
	at com.thingworx.webservices.BaseService.handleInvoke(BaseService.java:3487)
	at com.thingworx.webservices.BaseService.service(BaseService.java:487)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:623)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:199)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:144)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:168)
	at com.thingworx.security.authentication.sso.SSOSecurityContextFilter.doFilter(SSOSecurityContextFilter.java:47)
	at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:145)
	at com.thingworx.security.contenttype.ContentLengthFilter.doFilter(ContentLengthFilter.java:73)
	at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:22)
	at com.thingworx.security.authentication.AuthenticationFilter.propagateRequest(AuthenticationFilter.java:772)
	at com.thingworx.security.authentication.AuthenticationFilter.authenticate(AuthenticationFilter.java:612)
	at com.thingworx.security.authentication.AuthenticationFilter.doFilter(AuthenticationFilter.java:278)
	at com.thingworx.security.authentication.sso.SSORPUrlRewriteFilter.doFilter(SSORPUrlRewriteFilter.java:82)
	at com.thingworx.security.filter.ContentSecurityPolicyFilter.doFilter(ContentSecurityPolicyFilter.java:82)
	at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:329)
	at com.thingworx.security.filter.HttpResponseHeadersFilter.doFilter(HttpResponseHeadersFilter.java:172)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:168)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:90)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:482)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:130)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:93)
	at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:660)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:346)
	at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:383)
	at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:63)
	at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:937)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1791)
	at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:52)
	at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1190)
	at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:63)
	at java.base/java.lang.Thread.run(Thread.java:829)
Best answer by pshashipreetham
Thanks, @smainente, for the response. My mistake was upgrading the DB (by dump and restore) to a separate server instead of the server where the Postgres DB was installed and running.
I re-done the upgrade on the same server where the DB is existing. It was working fine. Seems like a permission or something.
This usually happens when the platform times out the request. Either your QA database is slow to respond, or the QA environment has shorter timeouts. These timeouts are set on the PersistenceProvider.
pshashipreetham18-OpalAuthorAnswer
18-Opal
March 4, 2025
