Edge file transfer to RTOS
rclarke
6-Contributor
Does anyone have any info / examples of coding file transfer capability via C Edge SDK for a device using a Real-Time Operating System such as uCOS? The particular target device of interest has constrained file handling capabilities based on an SD card file system. I'm familiar with general Edge SDK file transfer capabilities but could do with some pointers on the equivalent for a RTOS and what else has to be considered.
Thanks in advance,
Roy
smanley
(To:rclarke)
I can check internally on the necessary coding changed needed in the C SDK to set up file transfer to a RTOS.
