Edit JSON
AitorP
6-Contributor
Edit JSON
I have a JSON from Infotable, but I have a lot of information i don't need. I just want "rows". I do not want "datashape". What is the code to take only "rows" or delete the "datashape"?
json=
"rows":[
      {"Desc":"b",
       "Class":"d",
"dataShape":{
      "fieldDefinitions":{
                       "Desc":{
                              "name":"Desc",
                             "aspects":{"isPrimaryKey":false},
                            "description":"",
                            "baseType":"STRING",
                            "ordinal":2},
                       "Class":{
                             "name":"Class",
                            "description":"",
                            "ordinal":3},
2 REPLIES 2
AitorP
6-Contributor
(To:AitorP)
delete jsonData['dataShape'];
slangley
23-Emerald II
(To:AitorP)
Hi @AitorP.
We're not understanding your use case.  It should be possible to access the row element and ignore anything else.  If you can explain further, we will try to assist.
--Sharon
