I'm prototyping a mashup containing a map with some geo-fence / region overlay.
I would like to give a user the possibility to define their own regions, but it's not very convenient with the GoogleLocationPicker widget, the grid with points, add/delete buttons, etc... Ideally I would like to have the possibility to drag locations over the map and add/delete just like when you specify the routes in Google Maps.
Is any of that possible?
/ Constantine
Dragging is not supported. But you can have them directly pick points on the Google Map, the Google Map widget supports SelectedLocation
