Editable Temporary InfoTable in Mashup
ptc-6292144
3-Visitor
I am looking to have a service create a blank infotable and then put that infotable into a grid in a mashup. I then want to allow uses to add or delete rows within that temporary infotable from the mashup.
I have tried to accomplish this but I am getting mixed up in how to have the infotable in the grid refreshed after adding or deleting a row using services.
Any direction would be helpful.
Thank you,
Mike
5 REPLIES 5
adam11
(To:ptc-6292144)
Hi Mike,
Would you mind explaining the use case for this temporary InfoTable?
Adam,
Looking to have a 'add' and 'remove' function for certain options in a list on a mashup and I want those choices to then be filled in to a table to visualize the options the user has selected. Once they are done choosing, they will hit a submit button and those choices will be permanently added to a different table.
Thank you,
Mike
adam11
(To:ptc-6292144)
Mike,
Keep in mind, when modifying an
InfoTable
you need to pass the entire
InfoTable
 to the
Service
 adding or deleting rows. Presumably, you'll use two
Services
, one to add and one to remove a row, which will require you to pass the resulting
InfoTable
 back and forth between the two
Services
Here's sample code for an AddEntry()
Service
 which takes an
InfoTable
 and two strings as input:
// If no InfoTable exists, create one
if (!myInfoTable) {
  result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
    dataShapeName: "EntityList",
    infoTableName: "myInfoTable"
  // Add row to InfoTable
  result.AddRow();
else {
  // Otherwise, add row to InfoTable and return it
  myInfoTable.AddRow({ name: name, description: description });
  result = myInfoTable;
Adam,
I took your advice and I have the services setup, however the inputs being brought into the service aren't being added to the table. The service adds a row, but it just lists a blank row. I have put my code below. The "Add_Vocabulary_Term" and "Selected_Add_Tag" are string inputs from another part of the mashup (lists that our bound from the selected row). Selected_Tag_List is the table being brought in.
if(Add_Boolean==true){
    Selected_Tag_List.AddRow({
        Vocabulary: Add_Vocabulary_Term,
        Term: Selected_Add_Tag
    var result=Selected_Tag_List
else if(Remove_Boolean==true){
   var tableLength = Selected_Tag_List.getRowCount();
for (var x = 0; x < tableLength; x++) {
    if(Selected_Remove_Tag==Selected_Tag_List.rows.Term){
        Selected_Tag_List.RemoveRow(x)
Adam,
