Edition token in "Localization table" failed (Thingworx 8.3)
amejia1
6-Contributor
I'm trying to modify an existing token using the standard version of composer (not new composer) and it doesn't work, is that normal?
It works fine with version 8.2 but not with version 8.3.
Thank you.
posipova
20-Turquoise
(To:amejia1)
Please use the new composer. The issue will not be fixed in the classic one due  to it soon becoming obsolete.
posipova
20-Turquoise
(To:amejia1)
Does it work in the new composer?
amejia1
6-Contributor
(To:posipova)
Yes.
posipova
20-Turquoise
(To:amejia1)
