I'm trying to modify an existing token using the standard version of composer (not new composer) and it doesn't work, is that normal?
It works fine with version 8.2 but not with version 8.3.
Thank you.
Please use the new composer. The issue will not be fixed in the classic one due to it soon becoming obsolete.
Does it work in the new composer?
Yes.
