Hi experts,
I have email extension installed. I create a thing "MyMailServer2" based on it and it works if test it with script.
However, it doesn't work when I create a entity Notification "EmailNotify" and set "MyMailServer2" as the handler. I have no clue about it , could you help ?
===================Updated on Feb 9==============
I didn't figure out the problem above , then I tried to turn to script to send email. So I need to get the recipients defined in the Notification. I can get the notification content "testNotify" by running the service "GetNotificationContents", While executing the service "GetUserRecipientsOfEvent" , it tells me no notification conent found(see the Capture5.PNG) . Any idea about it ?
The Thingworx I installed from : twxFoundationH2Trial-8.3.2-windows-installer.zip
Version of email extension: 3.6.0
Sean
Thank you
Are there any errors in the Application Log when the even fires the notification?
No, I checked it but didn't find any error/warning log about it .
Since you don't see any error messages, I would put some logger statements in the code, to verify that it is trying to send the email.
Actually I tried to send email via script firstly and it works, but I don't want to hard code the recipients in script. so I tried two options: 1. Notification entity and 2. find recipients in the script. But the problems are :
Sean
You are using Navigate or the Manufacturing starter apps?
No, I'm using thingworx composer only
Ok so you should be able to add logger statements in your code to troubleshoot your issue.
Hi @seanccc.
If you have found a solution to your problem, please post it here and mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
Hi Sharon,
sorry, but I haven't found appropriate solution for it.
Sean
Were you able to get some more insight as to where the issue is by using the logger statements? What parts of the logic are properly executing and what values is it using etc?
