Embed Thingworx application in a Micro FrontEnd architecture
  • May 30, 2024
  • 2 replies
  • 2259 views
Hi all,
Sorry if my question is stupid but i don't know anything about Micro FrontEnd architecture and technology.
Do you know if it is possible to use Micro Frontend technologie to embed a thingworx application to avoid using IFrame?
Thanks for your help.
CB.
cbaurand12-AmethystAuthor
Hi VladimirN;
I think it was not my question. I don't speak about platform architecture. it is more "web" architecture. Can we embed mashups in Micro FrontEnd as we can do with iFrame ?
The context is, we have an angular Dashboard using Micro Frontend technology that gives acces to several appliquations. One of them is a TWX application and the question is, could we embed this application with the Micro frontEnd technology instead of using IFrame technogy.
18-Opal
May 30, 2024
Hi @cbaurand ,
I have done this in ReactJS; you can create the mashup on Thingworx. Then, create an Application Key and ensure it has the proper expiration date.
Then use the below Thingworx URL:
https://xyz.com/Thingworx/Mashups/MashupName?Parameter2=valuexyz&appKey=6b4668b0-1346-45bb-9892-f2f3d184b510&x-thingworx-session=true
Hi Shashi,
Thanks for your response. Do you mean, there is nothing to change in the TWX platform config like we have to do if we use IFrame ?
Is it as simple as you write ?
Cyril.
18-Opal
June 1, 2024
Hi @cbaurand ,
Yes, you need to make a CORS change in web.xml in the Apache Tomcat;
Below is the Article:
Article - CS229450 - How to Enable Cross-Origin Resource Sharing (CORS) in Apache Tomcat for ThingWorx Platform/ThingWorx Navigate (ptc.com)
