Enabling Tunneling of a thing under configuration tab through Edge Java SDK
kiran2
Hi Guys,
Need help in enabling tunneling of a particular thing through Edge Java SDK. I was able to add the tunnel by invoking AddTunnel service through Edge Java SDK.
Is there any service or property for EnableTunneling, so that i can invoke that service or else write the value to that property using SDK.
Thanks in advance.
CRArko
(To:kiran2)
Hello, Kiran.
Per the ThingWorx Edge SDK Help Center, it is suggested:
To enable tunneling, either invoke ClientConfigurator.tunnelsEnabled(true), or set the tunnelsEnabled directive in your config file. A full example is available in the TunnelExample.java file, located in the directory, samples/com/thingworx/sdk/simple.
Perhaps check for that example code, and see if that gives you what you need.
-- Craig A.
