Encrypt fields in User Extensions for a User
SOLVED
Highlighted
Participant
How can I encrypt fields like emailAddress and mobilePhone in the User Extensions tab for a particular user?
Can I remove some of the fields that I do not wish to be displayed?
1 ACCEPTED SOLUTION
Re: Encrypt fields in User Extensions for a User
All the fields in user extensions are typically property of a user .You can use setPropertyValues on a user to set all the property and use encryptStringWithKey function of Encryption Functions to encrypt particular property (I have not tested this) but I think this way it may work .
All these properties typically come from UserExtension Thing Shape .These are all inherited property from User Extension thing shape .So if you want to remove/add something you can do it in thing shape and it should reflect for every user .
Thanks ,
Mukul Narang
2 REPLIES 2
Thanks ,
Mukul Narang
Hi @rsubramanya.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
