Whenever I try to use the endpoint GetPartInPartsByID I get the following error :
Unable to execute service GetEndpointDefinition on AG_Odata_Connector : JSONObject["PTC.CADDocumentMgmt.AssociationTypeEnum"] not found.
I saw that there is a support article https://www.ptc.com/en/support/article/CS332815 for this and it has the following info :
However, my TW IR is 8.5.3 and Rest is 2.1 so there should be no issue.
So I am a bit confused on what to do to make this endpoint work.
From the OData Utilites I can easily use the v5/ProdMgmt service endpoint just not through Thingworx Service Definition.
Hi @NTailor
You mentioned that you're running ThingWorx IR 8.5.3, but that sounds like the ThingWorx Platform version. Can you please confirm the ThingWorx version and provide the Navigate version you are running?
--Sharon
