Enumerated property
sponomarenko-2
Enumerated property
Hi everybody,
How can I create an enumerated Thing property?
For example I have 3 options for "status" property: Critical, Low, Normal.
How can I define property to allow only one of the enumerated value?
I'm not speaking about any mashups and widgets. I want to provide data integrity on the model level.
Thanks in advance.
  Sergey
You can't out of the box. Various things to consider:
  • Not enumerated baseType
  • You can do it through DataTables to enumerate posible values, but there's isn't any kind of Data Integrity between a thing Property and a Data Table column value --> You can implement a data integrity system with events and route all the property update calls to a custom service
  • Also you will find that there isn't any data integrity either between DataTables --> Again you can implement your own Data Integrity system through custom service, it's a I pain yes.
Best Regards,
Carles.
