Ericsson Billing with ThingWorx
dmehdi-2
Hi Everyone,
Is it possible to integrate Ericsson billing with ThingWorx. Ericsson billing system is capable of encoding ASN.1 CDRs. Is it possible for the billing system to import the *.ASN1 CDR or ThingWorx and use it as a template to process it?
Aanjan
(To:dmehdi-2)
Danish, if you can convert the.asn1 to an xml or csv file, then you would be able to import that either through the ContentLoaderFunctions Resource or through the CSV Parser extension from the Marketplace.
5 REPLIES 5
Aanjan
(To:dmehdi-2)
dmehdi-2
(To:Aanjan)
Hi Ravi, a quick question here. Will it be the billing system to export/ftp relevant .asn1 files to ThingWorx? Also in the following connectivity diagram:
https://www.dropbox.com/s/xf9ryuz28013usy/Connectivity%20Diagram.jpg?dl=0
Where will be the existence of provisioning system. Kindly support me on these questions. Its quite urgent. Thanks.
Thanks a lot for your quick reply Ravi. I would also like to add one more question as I am stuck with it, how can we explain the E2E network connectivity of Ericsson Billing System and ThingWorx. I will appreciate you support on these lines.
Aanjan
(To:dmehdi-2)
Can you give me more information regarding the E2E connectivity? Also, do you have a point of contact from our Sales team?
dmehdi-2
(To:Aanjan)
Hi Ravi, I was concerned about the End to End network connectivity of ThingWorx and where we will find Ericsson billing in the total architecture. Mr. Chris Diment is assigned our account.
