Error 1003
khamlin
Error 1003
New to ThingWorx and doing a quick eval as a consultant for a large public company.  After signing up I'm getting an error 1003, which I believe to be an authentication error (based on a quick search of this community).  It says to contact the team.  How do I do that?  The phone number doesn't answer.  Not a good start for the evaluation!
Ken
6 REPLIES 6
AdamR
(To:khamlin)
Ken,
Just to be sure are you trying to load the Guided Experience or Quick Start evaluations?  We can check on your instance and what that status of the issue is.
Adam Ressler
Thingworx Support
khamlin
(To:AdamR)
Thanks for the reply Adam.
Actually neither one seems to work, but I'm getting the 1003 error with the Guided Experience.  When I try to Quick Start for the phone I get to Step 1 (View Mashup) and the resulting HTML page does nothing.  Upon inspection of the DOM, it appears elements are there but with a display:none style.  I don't know if that's related to an authentication issue or not.
Thanks for your help,
Ken
Howdy Ken,
Oh the phone QuickStart you should not have been able to get there without a successful authentication. The Phone path should be clear for you. Did you get the 1003 error from the Phone example?
Looking at your records, I see that you ran through the PC EMS example, and that you do have a Guided Experience instance allocated, however there may be a problem with you logging into those App QuickStarts.
I will cycle your instance and see if that clears it up.
Thanks!
-K
Kevin,
Thanks!  I will check on this tomorrow and let you know.  Thanks for the help!
Ken
It looks like you may have been impacted by the AWS issues experienced in the Eastern US this morning. Your instance of ThingWorx did not get properly provisioned.
I removed that instance and you should get a new one assigned to you once you click on "App QuickStarts" again.
Can you let us know whether this resolves your issue?
Thanks!
-K
Kevin,
It seems to be working!!  Thanks!  I'm off to explore and evaluate.  Your help was much appreciated!
Kind regards,
Ken
