I am transferring a zip file from server to remotethingwithfiletransfer in agent(EdgeSDK .net code ). But i the file is not copied to agent's virtual directory and i am getting the below error "The given key was not present in the dictionary." in the result of calling copy service in thingworx server. Let me know if you could help me in resolving the same.
Thanks.
Check read/write permissions of your Repositories. It should be creating some sort of Temp subfolder I believe, might be failing that.
Hi Now we are getting different error. The file is transferred from server repository to SDK solutions virtual directory. The file is transferred but in the result infotable of copy service
We had tried the same code with two different sdks. The code provided below is put into the service of a thing in server.
var params = {
async: false /* BOOLEAN */,
sourceRepo: "Tierra" /* STRING */,
targetRepo: "Prescription" /* STRING */,
targetFile: FileName /* STRING */,
targetPath: "In" /* STRING */,
sourceFile: FileName /* STRING */,
sourcePath: "/" /* STRING */,
timeout: 150000 /* INTEGER */
ServerDirectory is a thing based on FileRepository. SDKCommonThing is a thing on the Dot net EDGE SDK side. We are not sure what causes Unable To Convert From InfoTable to INFOTABLE.
Let me know if you could provide any input on the same.
Given Result Table Below:
targetChecksum | code | isAsync | maxSize | sourceFile | startPosition | duration | isRestartEnabled | targetFile | startTime | state | sourcePath | blockCount | sourceRepository | bytesTransferred | targetPath | sourceChecksum | message | transferId | blockSize | size | endTime | targetRepository | user | isComplete |
3fa8a947d6ce15fa97e1bd7cf860112f | 500 | false | 100000000 | Prescription001.zip | 0 | 835 | true | Prescription001.zip | 2015-09-22 12:03:43 | ERROR | /Outgoing/Prescription001.zip | 12 | Tierra | 771137 | In/Incoming/Prescription001.zip | 3fa8a947d6ce15fa97e1bd7cf860112f | Unable To Convert From InfoTable to INFOTABLE | d3f0a7e5-3724-43cd-9954-b42c958e663e | 65536 | 771137 | 2015-09-22 12:03:44 | Prescription | Administrator | false |
If this is the standard messages that the File transfer should be generating, then it looks like it may be a bug. Please submit this at support.ptc.com
