Error - Concurrent Modification Exception
Sathishkumar_C
Hi..
I have created a service with input of two strings and output will be the infotable.
While testing a service in background it is working fine.
But, in run time on mashup Input was getting from two drop down and output was given to a bar chart .
I am facing error "Wrapped java.util.ConcurrentModificationException".
I could not see any error on script.
How can i resolve this issue?
Thanks & Regards,
Sathishkumar C.
2 REPLIES 2
Sathishkumar C​: Could you please provide additional info with snapshot of your mashup with connection details. Is the data source for 2 drop down same? Are you sending the values from the 2 drop down with some button press or selection ?
-Durgesh
Hi Durgesh,
I am using two dropdown with different data source. Running a service with "Selected Row Changed" event of second drop down button.
Is there any solution?
Thanks & Regards,
Sathishkumar C.
