Hi All,
I am using Thingworx 7.3. It throwing error ("Error executing batch") continuously on Application Log. I don't have any idea about this.
What is this error?
I have recently imported Relational Databases Connectors extension from Thingworx market place. Is there any idea about this?
Thanks & Regards,
Sathishkumar C.
Hi Sathishkumar, have you checked if there is any scheduler or timer executing in the background? May be one you created or it simply got created when you imported some extension?
Could you add the application log here so we could review it?
Thank you for yo response.
Here the logs,
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] FileTransfer Subsystem Settings
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ----------------------------------------
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thread Pool Minimum Size = 10
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thread Pool Maximum Size = 10
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Queue Size = 100
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Thread Life = 600000
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] File Transfer Idle Timeout = 30000
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max File Transfer Size = 100000000
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max File Transfers Allowed in Offline Queue = 50000
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max File Transfers Allowed Per Thing in Offline Queue = 10
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Time To Live (sec) of File Transfer in Offline Queue = 86400
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] FileTransfer Idle Timeout for Edge Controlled Transfers = 600000
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Concurrent Edge Controlled File Transfers Allowed = 500
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Concurrent Edge Controlled File Transfers Allowed Per Thing = 2
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting All Things...
2017-12-15 09:15:02.404+0530 [L: WARN] [O: c.t.t.Thing] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-1-worker-2] Thing [SubStation01] has logged properties but does not have a valid value stream assigned
2017-12-15 09:15:02.404+0530 [L: WARN] [O: c.t.t.Thing] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-1-worker-2] Thing [En.Navigation03] has logged properties but does not have a valid value stream assigned
2017-12-15 09:15:02.404+0530 [L: WARN] [O: c.t.t.Thing] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-1-worker-2] Thing [demothing] has logged properties but does not have a valid value stream assigned
2017-12-15 09:15:03.091+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Activating Subscriptions...
2017-12-15 09:15:03.091+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Activating Property Bindings...
2017-12-15 09:15:03.091+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Initializing Subscriptions relationships...
2017-12-15 09:15:03.106+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Initializing Property Binding relationships...
2017-12-15 09:15:03.106+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Sending Post Start Notifications...
2017-12-15 09:15:03.153+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thingworx Server Application...ON
2017-12-15 09:15:03.481+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Datastore database...INITIALIZED
2017-12-15 09:15:10.501+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:16:02.408+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1] Thingworx System Metrics
AlertProcessingSubsystem#, maximumQueueSize= 50000.0, queueSize= 4.0, totalAlertsQueued= 4.0,
AlwaysOnSubsystem#, messageQueueSize= 0.0, messageThreadPoolSize= 0.0, messageActiveThreadCount= 0.0, messageLargestPoolSize= 0.0, messageCompletedTaskCount= 0.0, minaThreadPoolSize= 0.0, minaActiveThreadCount= 0.0, minaLargestPoolSize= 0.0, minaCompletedTaskCount= 0.0,
EventProcessingSubsystem#, corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 5.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 5.0, submitedTaskCount= 5.0, completedTaskCount= 5.0,
FederationSubsystem#, clientCount= 0.0, publishedCount= 0.0, updateInterval= 100.0,
FileTransferSubsystem#, corePoolSize= 10.0, maxPoolSize= 10.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
MessageStoreSubsystem#, corePoolSize= 10.0, maxPoolSize= 100.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
PlatformSubsystem#, eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.35846784E8, totalMemoryAllocated= 6.0817408E8, thingCount= 42.0,
StreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 250000.0, queueSize= 0.0, totalWritesQueued= 0.0, totalWritesPerformed= 0.0, numberOfProcessingThreads= 5.0,
TunnelSubsystem#, activeTunnelCount= 0.0, totalTunnelCount= 0.0,
UserManagementSubsystem#, userCount= 2.0,
ValueStreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 251.0, totalWritesPerformed= 251.0, numberOfProcessingThreads= 5.0,
WSCommunicationsSubsystem#, activeWebsockets= 0.0,
WSExecutionProcessingSubsystem#, corePoolSize= 1000.0, maxPoolSize= 10000.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
ThingworxServer#, systemRuntime= 0 hours, memoryInUse = 0.236 GB, totalMemoryAllocated= 0.608 GB, activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 09:16:03.354+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:16:13.224+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:16:58.549+0530 [L: ERROR] [O: c.t.p.p.PostgresDataExceptionTranslator] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [message: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]]
2017-12-15 09:16:58.616+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@140e0d66][message: Execution error in service script [En.DataAccess Last30DaysPeakLoad] : Wrapped java.lang.RuntimeException: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.] Cause: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]]
2017-12-15 09:17:03.127+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:17:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:18:03.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:18:13.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:19:03.238+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:19:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:20:03.127+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:20:13.123+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:21:03.240+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:21:13.148+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:22:03.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:22:13.123+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:23:03.193+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:23:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:24:03.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:24:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:25:03.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:25:13.248+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:26:03.198+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:26:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:27:03.147+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:27:13.140+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:28:03.175+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:28:13.153+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:29:03.162+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:29:13.144+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:30:03.138+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:30:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:31:03.187+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:31:13.175+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:32:03.200+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:32:13.148+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:33:03.138+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:33:13.145+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:34:03.200+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:34:13.165+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:35:03.168+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:35:13.147+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:36:03.174+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:36:13.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:37:03.158+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:37:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:38:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:38:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:39:03.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:39:13.150+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:40:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:40:13.142+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:41:03.161+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:41:13.156+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:42:03.161+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:42:13.140+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:43:03.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:43:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:44:03.165+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:44:13.146+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:45:03.212+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:45:13.139+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:46:02.490+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1] Thingworx System Metrics
AlertProcessingSubsystem#, maximumQueueSize= 50000.0, queueSize= 5.0, totalAlertsQueued= 5.0,
EventProcessingSubsystem#, corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 155.0, completedTaskCount= 155.0,
PlatformSubsystem#, eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.98451328E8, totalMemoryAllocated= 9.1226112E8, thingCount= 42.0,
ValueStreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 6543.0, totalWritesPerformed= 6543.0, numberOfProcessingThreads= 5.0,
ThingworxServer#, systemRuntime= 0 hours, memoryInUse = 0.298 GB, totalMemoryAllocated= 0.912 GB, activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 09:46:03.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:46:08.292+0530 [L: ERROR] [O: c.t.p.p.PostgresDataExceptionTranslator] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [message: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]]
2017-12-15 09:46:08.298+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@29676d2a][message: Execution error in service script [En.DataAccess Last30DaysPeakLoad] : Wrapped java.lang.RuntimeException: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.] Cause: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]]
2017-12-15 09:46:13.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:46:40.059+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@499608bb][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:47:03.153+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:47:10.031+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@62c03879][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:47:13.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:47:40.020+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@1c8f5631][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:48:03.163+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:48:10.037+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@23b760b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:48:13.149+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:48:40.006+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@23c3b00b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:49:03.151+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:49:10.044+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@58c831a9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:49:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:49:40.020+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@4dc7457b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:50:03.224+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:50:10.032+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@60177cfb][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:50:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:50:40.007+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@1bdae1c0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:51:03.152+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:51:09.987+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@649f00c4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:51:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:51:40.009+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@477cc814][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:52:03.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:52:10.017+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@36748326][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:52:13.140+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:52:40.010+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@57f57ee8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:53:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:53:10.038+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@1f886234][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:53:13.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:53:40.043+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@5118e3fd][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:54:03.182+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:54:10.029+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@3a32b5c8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:54:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:54:40.024+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@79ff64bd][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:55:03.149+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:55:10.031+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@7db7c929][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:55:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:55:40.030+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@30e6c158][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:56:03.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:56:10.033+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@3df5f48c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:56:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:56:40.043+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@49628c9a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:57:03.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:57:10.054+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@27c405e7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:57:13.141+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:57:40.043+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@57d39fdf][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:58:03.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:58:10.055+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@16b8604e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:58:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:58:40.066+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@5b537bad][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:59:03.163+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:59:10.021+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@2ef3f85d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:59:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:59:40.045+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@601db0e7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:00:03.149+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:00:10.096+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@7fbb51e9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:00:13.145+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:00:40.044+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@24da35e0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:01:03.171+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:01:10.044+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@6b7973b1][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:01:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:01:40.033+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@5e2f51d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:02:03.151+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:02:10.047+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@61d59d11][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:02:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:02:40.043+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@6033eaf8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:03:03.164+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:03:10.083+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@3ef5dd21][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:03:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:03:40.054+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@5573ee5a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:04:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:04:10.061+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@112b2399][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:04:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:04:40.091+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@d5596ca][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:05:03.145+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:05:10.173+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@177a807c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:05:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:05:40.101+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@5747131c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:06:03.167+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:06:10.068+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@16e81113][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:06:13.151+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:06:40.061+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@96972c9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:07:03.153+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:07:10.089+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@5bb268d4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:07:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:07:40.057+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@1d2671d4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:08:03.178+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:08:10.085+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@3e6689d0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:08:40.078+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@45e913c1][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:09:03.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:09:10.075+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@78cc82a7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:09:13.139+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:09:40.052+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@3be2fd41][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:10:03.167+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:10:10.085+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@2b441e7f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:10:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:10:40.078+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@3a5feb84][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:11:03.127+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:11:10.210+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@6aa8cc94][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:11:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:11:40.085+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@1241b4cf][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:12:03.174+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:12:10.083+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@5f6cb610][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:12:13.150+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:12:40.111+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@4729c216][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:13:03.126+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:13:10.133+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@28cf62b7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:13:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:13:38.692+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@2828ab0f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:14:03.121+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:14:10.187+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@3426627c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:14:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:14:40.110+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@f9aebae][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:15:03.146+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:15:10.114+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@4035c3f6][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:15:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:15:40.103+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@56ea0465][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:16:02.597+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1] Thingworx System Metrics
AlertProcessingSubsystem#, maximumQueueSize= 50000.0, queueSize= 13.0, totalAlertsQueued= 13.0,
EventProcessingSubsystem#, corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 305.0, completedTaskCount= 305.0,
PlatformSubsystem#, eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 5.92518328E8, totalMemoryAllocated= 9.1226112E8, thingCount= 42.0,
ValueStreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 12883.0, totalWritesPerformed= 12883.0, numberOfProcessingThreads= 5.0,
ThingworxServer#, systemRuntime= 1 hours, memoryInUse = 0.593 GB, totalMemoryAllocated= 0.912 GB, activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 10:16:03.124+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:16:10.190+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@67acb34f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:16:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:16:40.130+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@23bb38d3][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:17:03.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:17:10.118+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@70d1308][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:17:13.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:17:40.107+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@5b3c431f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:18:03.142+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:18:10.143+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@1edd543d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:18:13.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:18:40.105+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@1e0e50c7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:19:03.124+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:19:10.119+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@1868f95d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:19:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:19:40.103+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@5b6ab50][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:20:03.126+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:20:10.144+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@63df1de2][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:20:13.123+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:20:40.249+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@239cd5af][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:21:03.118+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:21:10.114+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@4a2ab8c1][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:21:13.120+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:21:40.104+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@1ff2f14d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:22:03.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:22:10.149+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@2610828d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:22:11.122+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@702839f3][message: Execution error in service script [En.AlertsAndEvents NumberOfUnackAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Execution error in service script [En.AlertsAndEvents AllUnackAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Execution error in service script [En.AlertsAndEvents AllAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Thing [EnSystem05] is not running Cause: Thing [EnSystem05] is not running Cause: Execution error in service script [En.AlertsAndEvents AllAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Thing [EnSystem05] is not running Cause: Thing [EnSystem05] is not running Cause: Execution error in service script [En.AlertsAndEvents AllUnackAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Execution error in service script [En.AlertsAndEvents AllAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Thing [EnSystem05] is not running Cause: Thing [EnSystem05] is not running Cause: Execution error in service script [En.AlertsAndEvents AllAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Thing [EnSystem05] is not running Cause: Thing [EnSystem05] is not running]
2017-12-15 10:22:13.118+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:22:38.162+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:22:40.111+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@6207f4df][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:23:03.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:23:10.136+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@5593c067][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:23:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:23:40.112+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@3b3d7244][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:24:03.141+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:24:10.144+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@6082c6da][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:24:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:24:40.125+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@5e583833][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:25:03.138+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:25:10.107+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@7a8473be][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:25:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:25:40.135+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@1120cfe5][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:26:03.120+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:26:10.132+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@777af16e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:26:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:26:40.152+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@84d4fec][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:27:03.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:27:10.163+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@4c33d101][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:27:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:27:40.122+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@37d397e7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:28:03.164+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:28:10.142+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@1619a80][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:28:13.138+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:28:40.155+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@2df9a520][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:29:03.144+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:29:10.153+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@602bd058][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:29:13.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:29:40.133+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@31addcd4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:30:03.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:30:10.151+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@a939ab1][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:30:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:30:40.164+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@21d13877][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:31:03.170+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:31:10.170+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@1a727f66][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:31:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:31:40.154+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@2206abd3][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:32:03.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:32:10.150+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@64a013a0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:32:13.127+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:32:40.165+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@4e6ef20a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:33:03.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:33:10.163+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@70819dfc][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:33:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:33:40.163+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@46ffd352][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:34:03.167+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:34:10.152+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@2590424][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:34:13.139+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:34:40.173+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@33590497][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:35:03.166+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:35:10.168+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@1f8693c2][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:35:13.152+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:35:40.151+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@3b125194][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:36:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:36:10.179+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@17be6ceb][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:36:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:36:40.175+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@126a1f37][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:37:03.175+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:37:10.187+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@1f14117][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:37:13.147+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:37:40.179+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@1a5763fc][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:38:03.180+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:38:10.210+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@2b334c6][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:38:13.147+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:38:40.198+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@648e4d4e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:39:03.158+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:39:10.189+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@2e3ff9dd][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:39:13.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:39:40.205+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@1a7e528d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:40:03.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:40:10.185+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@3ea766e8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:40:13.145+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:40:40.307+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@6c201c41][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:41:03.227+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:41:10.191+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@18129a25][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:41:13.140+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:41:40.192+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@24ca2ebc][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:42:03.158+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:42:10.216+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@28bbc75a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:42:13.146+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:42:40.216+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@1bee6a37][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:43:03.156+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:43:10.194+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@7f11982b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:43:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:43:40.193+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@a4e0615][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:44:03.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:44:10.193+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@6b317576][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:44:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:44:40.198+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@336b784f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:45:03.157+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:45:10.187+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@2f802e5f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:45:13.151+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:45:40.193+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@17710bc3][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:46:02.704+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1] Thingworx System Metrics
AlertProcessingSubsystem#, maximumQueueSize= 50000.0, queueSize= 13.0, totalAlertsQueued= 49.0,
AlwaysOnSubsystem#, messageQueueSize= 0.0, messageThreadPoolSize= 0.0, messageActiveThreadCount= 0.0, messageLargestPoolSize= 0.0, messageCompletedTaskCount= 0.0, minaThreadPoolSize= 0.0, minaActiveThreadCount= 0.0, minaLargestPoolSize= 0.0, minaCompletedTaskCount= 0.0,
EventProcessingSubsystem#, corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 455.0, completedTaskCount= 455.0,
FederationSubsystem#, clientCount= 0.0, publishedCount= 0.0, updateInterval= 100.0,
FileTransferSubsystem#, corePoolSize= 10.0, maxPoolSize= 10.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
MessageStoreSubsystem#, corePoolSize= 10.0, maxPoolSize= 100.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
PlatformSubsystem#, eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 6.64284456E8, totalMemoryAllocated= 9.1226112E8, thingCount= 42.0,
StreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 250000.0, queueSize= 0.0, totalWritesQueued= 0.0, totalWritesPerformed= 0.0, numberOfProcessingThreads= 5.0,
TunnelSubsystem#, activeTunnelCount= 0.0, totalTunnelCount= 0.0,
UserManagementSubsystem#, userCount= 2.0,
ValueStreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 19478.0, totalWritesPerformed= 19478.0, numberOfProcessingThreads= 5.0,
WSCommunicationsSubsystem#, activeWebsockets= 0.0,
WSExecutionProcessingSubsystem#, corePoolSize= 1000.0, maxPoolSize= 10000.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
ThingworxServer#, systemRuntime= 1 hours, memoryInUse = 0.664 GB, totalMemoryAllocated= 0.912 GB, activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 10:46:03.118+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:46:10.216+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@24f5fc69][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:46:13.123+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:46:40.189+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@5f1bf3f6][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:47:03.139+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:47:10.211+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@21b0b88a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:47:13.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:47:40.225+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@1abb5b04][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:48:03.159+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:48:10.215+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@2529727b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:48:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:48:40.215+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@514a170e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:49:03.151+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:49:10.220+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@4b22d437][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:49:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:49:40.247+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@b92d1a2][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:50:03.157+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:50:10.227+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@2104ce3a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:50:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:50:40.216+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@2ff3ec0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:51:03.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:51:10.227+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@6245c5a5][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:51:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:51:40.227+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@1f364dcb][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:52:03.126+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:52:10.227+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@108b1d14][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:52:13.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:52:40.209+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@6305e171][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:53:03.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:53:10.234+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@3143bcbb][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:53:13.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:53:40.223+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@f93413e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:54:03.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:54:10.222+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@60678ab7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:54:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:54:40.245+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@1074bb7d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:55:03.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:55:10.229+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@19051ed5][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:55:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:55:40.239+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@7fdcc502][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:56:03.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:56:10.246+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@4e8c104a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:56:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:56:40.251+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@50c95397][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:57:03.162+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:57:10.263+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@5f576067][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:57:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:57:40.250+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@64532774][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:58:03.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:58:10.235+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@543592bd][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:58:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:58:40.234+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@2b7fee4f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:59:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:59:10.245+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@e9b383a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:59:13.126+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:59:40.251+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@6b7a5675][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:00:03.150+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:00:10.259+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@531dcf6][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:00:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:00:40.239+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@516fc98b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:01:03.144+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:01:10.261+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@31609376][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:01:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:01:40.246+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@6c01c68f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:02:03.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:02:10.268+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@2656a84a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:02:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:02:40.245+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@4a14b731][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:03:03.175+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:03:10.277+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@517600b4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:03:13.139+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:03:40.258+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@ee00136][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:04:03.151+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:04:10.279+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@502e7e84][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:04:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:04:40.279+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@7d967cb0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:05:03.169+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:05:10.292+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@f0abdbb][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:05:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:05:40.285+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@19e900d9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:06:03.177+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:06:10.265+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@79ccdf4e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:06:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:06:40.285+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@2964c25a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:07:03.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:07:10.288+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@5dadcc3a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:07:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:07:40.266+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@429c13a9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:08:03.152+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:08:10.286+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@a95161e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:08:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:08:40.301+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@623818fa][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:09:03.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:09:10.294+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@ca22366][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:09:13.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:09:40.271+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@29bc1ea8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:10:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:10:10.308+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@4e9cc355][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:10:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:10:40.281+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@37700e14][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:11:03.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:11:10.313+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@32a5a0bf][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:11:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:11:40.286+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@309b70d7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:12:03.188+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:12:10.303+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@2975864d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:12:13.155+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:12:40.307+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@5d5042b3][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:13:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:13:10.301+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@69e4248b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:13:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:13:40.302+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@3b13a764][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:14:03.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:14:10.316+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@20c35982][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:14:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:14:40.328+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@11dd73b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:15:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:15:10.313+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@267dba2d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:15:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:15:40.317+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@7ee3e7b8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:16:02.811+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1] Thingworx System Metrics
AlertProcessingSubsystem#, maximumQueueSize= 50000.0, queueSize= 4.0, totalAlertsQueued= 49.0,
EventProcessingSubsystem#, corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 605.0, completedTaskCount= 605.0,
PlatformSubsystem#, eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 5.84485152E8, totalMemoryAllocated= 9.1226112E8, thingCount= 42.0,
ValueStreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 26123.0, totalWritesPerformed= 26123.0, numberOfProcessingThreads= 5.0,
ThingworxServer#, systemRuntime= 2 hours, memoryInUse = 0.585 GB, totalMemoryAllocated= 0.912 GB, activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 11:16:03.148+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:16:10.321+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@2e6c6a3d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:16:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:16:40.323+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@461de856][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:17:03.158+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:17:10.309+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@2a8a1fec][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:17:13.139+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:17:40.323+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@6fa189db][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:18:03.127+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:18:10.338+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@40daaf4b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:18:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:18:40.320+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@1578ca32][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:19:03.149+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:19:10.329+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@4091cc4c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:19:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:19:40.325+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@57156e40][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:20:03.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:20:10.335+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@4d1f5c44][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:20:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:20:40.337+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@186b8455][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:21:03.168+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:21:10.329+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@5d83d5c0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:21:13.126+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:21:40.344+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@7ab47922][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:22:03.158+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:22:10.334+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@32680a41][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:22:13.142+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:22:40.324+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@24bbbb51][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:23:03.138+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:23:10.331+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@3f444b73][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:23:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:23:40.330+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@554afd97][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:24:03.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:24:10.341+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@4a185572][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:24:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:24:40.345+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@1fc0bf6][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:25:03.145+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:25:10.328+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@25b6542][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:25:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:25:40.323+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@6087bfc4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:26:03.156+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:26:10.346+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@1669eb8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:26:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:26:40.347+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@642a160e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:27:03.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:27:10.348+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@b4c1beb][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:27:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:27:40.359+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@14197b51][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:28:03.163+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:28:10.367+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@7e27f048][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:28:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:28:40.369+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@4df4b4ec][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:29:03.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:29:10.348+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@6def3f5b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:29:13.138+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:29:40.376+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@63f1482b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:30:03.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:30:10.365+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@64ac9f87][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:30:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:30:40.371+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@62678a4c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:31:03.152+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:31:10.371+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@45cf20c0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:31:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:31:40.368+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@9325804][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:32:03.147+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:32:08.747+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@4fb20b39][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:32:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:32:38.752+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@63fe6a6f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:33:03.165+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:33:08.745+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@1212d36e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:33:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:33:38.750+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@42e9ea36][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:34:03.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:34:08.773+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@11f3c049][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:34:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:34:38.767+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@25f54f81][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:35:03.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:35:08.755+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@334921fa][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:35:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:35:38.761+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@456cc1bd][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:36:03.169+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:36:08.762+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@1de7a11f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:36:13.127+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:36:38.786+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@710e99f3][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:37:03.140+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:37:08.769+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@49e87012][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:37:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:37:38.781+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@25f6ce5b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:38:03.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:38:08.765+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@4a07ba44][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:38:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:38:38.768+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@7c369c6f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:39:03.149+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:39:08.777+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@5fa3c651][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:39:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:39:38.790+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@13e2871a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:40:03.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:40:08.770+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@499c95f5][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:40:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:40:38.791+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@3678a896][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:41:03.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:41:08.793+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@437309eb][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:41:13.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:41:38.778+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@4d802850][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:42:03.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:42:08.802+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@364a0fa1][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:42:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:42:38.799+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@56a29df7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:43:03.156+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:43:08.803+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@6bd53cea][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:43:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:43:38.788+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@65c6cdb9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:44:03.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:44:08.801+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@24501fc6][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:44:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:44:38.815+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@5ead2b9b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:45:03.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:45:08.794+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@7e233160][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:45:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:45:38.813+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@4def385c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:46:02.919+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1] Thingworx System Metrics
AlwaysOnSubsystem#, messageQueueSize= 0.0, messageThreadPoolSize= 0.0, messageActiveThreadCount= 0.0, messageLargestPoolSize= 0.0, messageCompletedTaskCount= 0.0, minaThreadPoolSize= 0.0, minaActiveThreadCount= 0.0, minaLargestPoolSize= 0.0, minaCompletedTaskCount= 0.0,
EventProcessingSubsystem#, corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 755.0, completedTaskCount= 755.0,
FederationSubsystem#, clientCount= 0.0, publishedCount= 0.0, updateInterval= 100.0,
FileTransferSubsystem#, corePoolSize= 10.0, maxPoolSize= 10.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
MessageStoreSubsystem#, corePoolSize= 10.0, maxPoolSize= 100.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
PlatformSubsystem#, eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 6.11120864E8, totalMemoryAllocated= 9.1226112E8, thingCount= 42.0,
StreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 250000.0, queueSize= 0.0, totalWritesQueued= 0.0, totalWritesPerformed= 0.0, numberOfProcessingThreads= 5.0,
TunnelSubsystem#, activeTunnelCount= 0.0, totalTunnelCount= 0.0,
UserManagementSubsystem#, userCount= 2.0,
ValueStreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 32743.0, totalWritesPerformed= 32743.0, numberOfProcessingThreads= 5.0,
WSCommunicationsSubsystem#, activeWebsockets= 0.0,
WSExecutionProcessingSubsystem#, corePoolSize= 1000.0, maxPoolSize= 10000.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
ThingworxServer#, systemRuntime= 2 hours, memoryInUse = 0.611 GB, totalMemoryAllocated= 0.912 GB, activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 11:46:03.149+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 11:46:08.805+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@4875b427][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:46:13.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:46:38.807+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@345f59a1][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:47:03.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:47:08.810+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@4ceac388][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:47:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:47:38.803+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@39949613][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:48:03.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:48:08.813+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@349602][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:48:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:48:38.809+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@647ac2b8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:49:03.149+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:49:08.824+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@4d51adfe][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:49:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:49:38.804+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@69e08b64][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:50:03.158+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:50:08.834+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@52f3ae99][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:50:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:50:38.824+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@73ab599e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:51:03.152+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:51:08.834+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@7d534372][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:51:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:51:38.840+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@7654719f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:52:03.161+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:52:08.830+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@63a6b98e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:52:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:52:38.838+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@2de60322][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:53:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:53:08.842+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@4207064c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:53:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:53:38.821+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@628cbe9a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:54:03.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:54:08.850+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@6201099a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:54:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:54:38.851+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@5eb6b906][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:55:03.139+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 11:55:08.844+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@6a48a3ad][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:55:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:55:38.839+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@47e21391][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:56:03.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:56:08.846+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@6323f923][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:56:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:56:38.845+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@56f9f8ce][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:57:03.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:57:08.834+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@46b98faf][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:57:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:57:38.862+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@4e1244a3][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:58:03.141+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:58:08.847+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@7567bf78][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:58:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 11:58:38.835+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@4c1065d2][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:59:03.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 11:59:08.734+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@44bc904e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 11:59:13.161+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 11:59:38.739+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@737bb1a9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:00:03.153+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:00:08.738+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@146279ff][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:00:13.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:00:38.747+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@52ada778][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:01:03.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:01:08.747+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@25b8c6a7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:01:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:01:38.743+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@433d7ca6][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:02:03.155+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:02:08.745+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@4c4f8af4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:02:13.127+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:02:38.744+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@6b05a4a0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:03:03.154+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:03:08.742+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@2fdf5cf7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:03:13.142+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:03:38.757+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@4d84e4ce][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:04:03.160+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:04:08.744+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@71527880][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:04:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:04:38.729+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@9b16fff][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:05:03.142+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:05:08.752+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@6fdaf001][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:05:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:05:38.751+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@26fe6231][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:06:03.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:06:08.756+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@8bd23b8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:06:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:06:38.747+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@11514e04][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:07:03.162+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:07:08.760+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@79ada3c7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:07:13.147+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:07:38.754+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@af42899][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:08:03.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:08:08.759+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@23a56b3c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:08:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:08:38.778+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@5a5eb34d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:09:03.161+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:09:08.782+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@7694721a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:09:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:09:38.762+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@16662057][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:10:03.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:10:08.784+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@871d55e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:10:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:10:38.770+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@db244e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:11:03.162+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:11:08.765+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@1c930db7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:11:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:11:38.784+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@1df6ccc4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:12:03.163+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:12:08.774+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@3273e61b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:12:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:12:38.787+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@107ecd92][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:13:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:13:08.760+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@706b860e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:13:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:13:38.785+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@13deecf6][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:14:03.149+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:14:08.785+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@1863cf03][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:14:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:14:38.788+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@74479c42][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:15:03.141+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:15:08.769+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@6add4c15][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:15:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:15:38.779+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@38d671a6][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:16:02.903+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1] Thingworx System Metrics
AlertProcessingSubsystem#, maximumQueueSize= 50000.0, queueSize= 4.0, totalAlertsQueued= 49.0,
EventProcessingSubsystem#, corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 905.0, completedTaskCount= 905.0,
PlatformSubsystem#, eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 7.19113728E8, totalMemoryAllocated= 9.1226112E8, thingCount= 42.0,
ValueStreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 39289.0, totalWritesPerformed= 39289.0, numberOfProcessingThreads= 5.0,
ThingworxServer#, systemRuntime= 3 hours, memoryInUse = 0.719 GB, totalMemoryAllocated= 0.912 GB, activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 12:16:03.168+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:16:08.775+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@6947d7d0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:16:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:16:38.802+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@a9e4bf2][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:17:03.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:17:08.796+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@7e74c835][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:17:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:17:38.801+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@77b49db9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:18:03.162+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:18:08.789+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@4130a21a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:18:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:18:38.789+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@68febe32][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:19:03.139+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:19:08.811+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@345e84ad][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:19:13.144+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:19:38.801+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@76e89a28][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:20:03.156+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:20:08.806+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@66d7470d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:20:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:20:38.821+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@851c4f9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:21:03.154+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:21:08.818+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@65a843c7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:21:13.154+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:21:40.418+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@a7155a3][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:22:03.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:22:10.445+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@2e3d4ff1][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:22:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:22:40.435+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@2d291ccf][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:23:03.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:23:10.431+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@3671070a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:23:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:23:40.438+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@354bfd9b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:24:03.160+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:24:10.419+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@6c996f4f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:24:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:24:40.420+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@2fea091c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 12:25:02.296+0530 [L: INFO] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] Starting entity import
2017-12-15 12:25:03.154+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:25:04.365+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@36d3c81c][message: Thing [EN.Common] is not running]
2017-12-15 12:25:04.365+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@56d51f24][message: Thing [En.AlertsAndEvents] is not running]
2017-12-15 12:25:05.209+0530 [L: WARN] [O: c.t.t.Thing] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] Thing [En.Navigation03] has logged properties but does not have a valid value stream assigned
2017-12-15 12:25:05.210+0530 [L: WARN] [O: c.t.t.Thing] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] Thing [SubStation01] has logged properties but does not have a valid value stream assigned
2017-12-15 12:25:05.211+0530 [L: WARN] [O: c.t.t.Thing] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] Thing [demothing] has logged properties but does not have a valid value stream assigned
2017-12-15 12:25:05.235+0530 [L: INFO] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] Entity import successful
2017-12-15 12:25:13.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:26:05.289+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:26:15.260+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:27:05.283+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:27:15.265+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:28:05.263+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:28:15.248+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:29:05.269+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:29:15.254+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:30:05.328+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:30:15.259+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:31:05.292+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:31:15.269+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:32:05.276+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:32:05.283+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:32:15.271+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:33:02.123+0530 [L: INFO] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] Starting entity import of C:\ThingworxStorage\extensions\temp\126-ChartWidget_ExtensionPackage_v2.03_52d5cf29-bc13-4504-8852-933855abeae9\126-ChartWidget_ExtensionPackage_v2.03\metadata.xml
2017-12-15 12:33:02.209+0530 [L: INFO] [O: c.t.migration] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] Export file missing version information. No migration will be performed.
2017-12-15 12:33:02.209+0530 [L: INFO] [O: c.t.w.Importer] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] Successfully added for import C:\ThingworxStorage\extensions\temp\126-ChartWidget_ExtensionPackage_v2.03_52d5cf29-bc13-4504-8852-933855abeae9\126-ChartWidget_ExtensionPackage_v2.03\metadata.xml
2017-12-15 12:33:02.209+0530 [L: WARN] [O: c.t.e.u.ExtensionPackageUtilities] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] Deprecated extension structure: The element, DefaultChartAxisStyle, was found in metadata.xml and is a deprecated pattern for defining StyleDefinitions in an extension. Please refer to Project and Extension File Structure in the ThingWorx Extension Development Guide for more information.
2017-12-15 12:33:02.209+0530 [L: WARN] [O: c.t.e.u.ExtensionPackageUtilities] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] Deprecated extension structure: The element, DefaultChartBodyStyle, was found in metadata.xml and is a deprecated pattern for defining StyleDefinitions in an extension. Please refer to Project and Extension File Structure in the ThingWorx Extension Development Guide for more information.
2017-12-15 12:33:05.294+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:33:15.278+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:33:35.297+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:33:45.299+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:34:05.284+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:34:15.260+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:35:05.281+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:35:15.270+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:36:05.259+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:36:15.255+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:37:05.291+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:37:15.264+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:38:05.275+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:38:15.262+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:39:05.281+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:39:15.263+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:40:05.318+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:40:15.250+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:41:05.285+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:41:15.266+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:42:05.294+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:42:15.273+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:43:05.278+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:43:15.269+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:44:05.292+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:44:15.256+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:45:05.283+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:45:15.251+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:46:03.010+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1] Thingworx System Metrics
AlertProcessingSubsystem#, maximumQueueSize= 50000.0, queueSize= 4.0, totalAlertsQueued= 53.0,
EventProcessingSubsystem#, corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 1060.0, completedTaskCount= 1060.0,
PlatformSubsystem#, eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 3.34865072E8, totalMemoryAllocated= 9.2798976E8, thingCount= 42.0,
ValueStreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 46776.0, totalWritesPerformed= 46776.0, numberOfProcessingThreads= 5.0,
ThingworxServer#, systemRuntime= 3 hours, memoryInUse = 0.335 GB, totalMemoryAllocated= 0.928 GB, activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 12:46:05.295+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:46:15.254+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:47:05.259+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:47:05.275+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:47:15.253+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:48:05.277+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:48:15.261+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:49:05.259+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:49:15.250+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:50:05.281+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 12:50:15.256+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:51:05.282+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:51:15.281+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:52:05.266+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:52:15.258+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:53:05.300+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:53:15.256+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:54:05.269+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:54:15.250+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:55:05.277+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:55:15.253+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 12:56:05.275+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 12:56:15.267+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:57:05.285+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:57:15.278+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:58:05.259+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:58:15.263+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 12:59:05.271+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 12:59:15.257+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:00:05.258+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:00:15.254+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:01:05.264+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:01:15.258+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:02:05.266+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:02:15.243+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:03:05.269+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:03:15.251+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:04:05.279+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:04:15.252+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:05:05.294+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:05:15.269+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:06:05.294+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:06:15.257+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:07:05.279+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:07:15.258+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:08:05.259+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:08:15.253+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:09:05.275+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:09:15.262+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:10:05.262+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:10:15.268+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:11:05.277+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:11:15.249+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:12:05.290+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:12:15.251+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:13:05.251+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:13:15.253+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:14:05.285+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:14:15.261+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:15:05.285+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:15:15.267+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:16:03.118+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1] Thingworx System Metrics
AlertProcessingSubsystem#, maximumQueueSize= 50000.0, queueSize= 4.0, totalAlertsQueued= 55.0,
AlwaysOnSubsystem#, messageQueueSize= 0.0, messageThreadPoolSize= 0.0, messageActiveThreadCount= 0.0, messageLargestPoolSize= 0.0, messageCompletedTaskCount= 0.0, minaThreadPoolSize= 0.0, minaActiveThreadCount= 0.0, minaLargestPoolSize= 0.0, minaCompletedTaskCount= 0.0,
EventProcessingSubsystem#, corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 1210.0, completedTaskCount= 1210.0,
FederationSubsystem#, clientCount= 0.0, publishedCount= 0.0, updateInterval= 100.0,
FileTransferSubsystem#, corePoolSize= 10.0, maxPoolSize= 10.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
MessageStoreSubsystem#, corePoolSize= 10.0, maxPoolSize= 100.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
PlatformSubsystem#, eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 6.48134488E8, totalMemoryAllocated= 9.2798976E8, thingCount= 42.0,
StreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 250000.0, queueSize= 0.0, totalWritesQueued= 0.0, totalWritesPerformed= 0.0, numberOfProcessingThreads= 5.0,
TunnelSubsystem#, activeTunnelCount= 0.0, totalTunnelCount= 0.0,
UserManagementSubsystem#, userCount= 2.0,
ValueStreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 54010.0, totalWritesPerformed= 54010.0, numberOfProcessingThreads= 5.0,
WSCommunicationsSubsystem#, activeWebsockets= 0.0,
WSExecutionProcessingSubsystem#, corePoolSize= 1000.0, maxPoolSize= 10000.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
ThingworxServer#, systemRuntime= 4 hours, memoryInUse = 0.648 GB, totalMemoryAllocated= 0.928 GB, activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 13:16:05.290+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:16:15.256+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:17:05.279+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:17:15.263+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:18:05.272+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:18:15.261+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:19:05.291+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:19:15.255+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:20:05.263+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:20:15.248+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:21:05.267+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:21:15.250+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:22:05.271+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:22:15.275+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:23:05.274+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:23:15.264+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:24:05.290+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:24:15.251+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:25:05.262+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:25:15.248+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:26:05.279+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:26:15.258+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:27:05.288+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:27:15.254+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:28:05.268+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:28:15.273+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:29:05.299+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:29:15.278+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:30:05.278+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:30:15.261+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:31:05.278+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:31:15.273+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:32:05.285+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:32:15.252+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:33:05.263+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:33:15.263+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:34:05.286+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:34:15.252+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:35:05.305+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:35:15.251+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:36:05.246+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:36:15.250+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:37:05.289+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:37:15.246+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:38:05.269+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:38:15.254+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:39:05.283+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:39:15.250+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:40:05.265+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:40:15.252+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:41:05.265+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:41:15.251+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:42:05.295+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:42:15.249+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:43:05.253+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:43:15.256+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:44:05.298+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:44:15.248+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:45:05.284+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:45:15.262+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:46:03.225+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1] Thingworx System Metrics
AlertProcessingSubsystem#, maximumQueueSize= 50000.0, queueSize= 4.0, totalAlertsQueued= 58.0,
EventProcessingSubsystem#, corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 1360.0, completedTaskCount= 1360.0,
PlatformSubsystem#, eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 8.07834152E8, totalMemoryAllocated= 9.2798976E8, thingCount= 42.0,
ValueStreamProcessingSubsystem#, maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 60935.0, totalWritesPerformed= 60935.0, numberOfProcessingThreads= 5.0,
ThingworxServer#, systemRuntime= 4 hours, memoryInUse = 0.808 GB, totalMemoryAllocated= 0.928 GB, activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 13:46:05.269+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:46:15.257+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:47:05.268+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:47:15.256+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:48:05.284+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:48:15.261+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:49:05.301+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:49:15.262+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:50:05.268+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:50:15.252+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:51:05.272+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:51:15.264+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:52:05.273+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 13:52:15.247+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:53:05.282+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:53:15.252+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:54:05.296+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:54:15.257+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:55:05.247+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:55:15.248+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:56:05.291+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:56:15.261+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:57:05.263+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 13:57:15.248+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:58:05.263+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 13:58:15.261+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 13:59:05.291+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 13:59:15.267+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 14:00:05.276+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 14:00:15.252+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 14:01:05.271+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 14:01:15.249+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 14:02:05.294+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 14:02:15.255+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 14:03:05.274+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 14:03:15.254+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 14:04:05.288+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 14:04:15.256+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 14:05:05.268+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 14:05:15.271+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 14:06:05.292+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 14:06:15.258+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 14:07:05.244+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 14:07:15.250+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 14:08:05.289+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 14:08:15.259+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 14:09:05.276+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 14:09:15.266+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 14:10:05.298+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 14:10:15.298+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 14:11:05.284+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 14:11:15.280+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 14:12:05.269+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 14:12:15.247+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 14:13:05.249+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 14:13:15.256+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 14:14:05.290+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 14:14:15.257+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
Thanks and Regards,
Sathishkumar C
Thank you for sharing, its generated by the BatchStreamEntryProcessor, looks like some issue with the processing of stream entries, I also notice that you have DataStore unknown error for PostgreSQL. Are you using PostgreSQL as your persistence provider? If yes could you confirm that there are no connectivity issues.
How often are you writing to the Stream? Does the issue persist despite server restart?
Hi
Thank you for your response.
Every minute i am updating a Value stream.
Yeah.. I am using PostgreSQL DB and not able to get history of logged property from a value stram.
How can i resolve this issue?
Sathishkumar C.
How are you writing to this ValueStream? Are both ThingWorx Server and the PostgreSQL DB both running on same machine? Could you confirm if the PostgreSQL is up and running and if you are able to connect to the instance via the PGAdmin client? Also it'll be worth checking if there's enough disk space left on the drive where PostgreSQL is installed.
Hi..
Thanks and Regards,
Sathishkumar C.
Anyone..
This problem ("Error executing batch'") still persists. Anyone having idea regarding this.
It will be very helpful, if any solution available for this issue...
I can't able to access history of logged property.
Thanks & Regards,
Sathishkumar C
Hi Sathishkumar C if you have access to the PTC Support, could you please open a support case for this. I think it needs to be reviewed live may be with a Webex session.
OK .
Thank you.
Have you got any reply on this we are also facing same issue.
