How to generate PMML for model using clustering_microservice.It will be helpful if explained in detail steps.
Hi @user539
To generate a cluster model you need to access the AnalyticsServer_ClusteringThing, service CreateJob
When you execute this, add the datasetUri you find in Builder in the datasetRef infoTable (click the InfoTable icon, then Add, then paste the datasetUri in the datasetUri field, enter parquet for format, leave the other fields as default, press Add)
enter the clusterCount (3 for example)
Execute the service.
This will give you a jobId as output.
Copy this jobId.
Access the service RetrieveModel, fill the jobId and execute.
This will give you the pmml file
Kind regards
Christophe
Hi @user539
Copy this jobId.
Kind regards
Christophe
Hi @cmorfin your post works for me.I have a small doubt.Why should me mention format as PARQUET in editing infotable as out input is csv and output is going to be xml ?
Hi @user539
In the steps above I am assuming the dataset has been uploaded to Builder.
Though you initially upload a csv file, it is internally stored as a parquet file, hence the parquet format .
Kind regards
Christophe
