Error Installing ThingWorx
emoreira
For some reason I cannot install TW in my local machine anymore. I uninstalled Tomcat, cleared all caches, and deployed TW and still get an error message:
HTTP Status 401 - Could not handle request
type Status report
message Could not handle request
description This request requires HTTP authentication.
Looking at Tomcat´s log I've found this:
java.lang.NullPointerException
at java.io.File.<init>(Unknown Source)
at com.thingworx.extensibility.utils.ExtensionPackageUtilities.cleanJarDeploymentLocation(ExtensionPackageUtilities.java:1292)
at com.thingworx.system.managers.ExtensionPackageManager.initializeCollection(ExtensionPackageManager.java:112)
at com.thingworx.system.entities.ThingWorxEntityManager.initializeCollections(ThingWorxEntityManager.java:176)
at com.thingworx.system.ThingWorxServer.Initialize(ThingWorxServer.java:110)
at com.thingworx.system.ThingWorxBootstrapper.contextInitialized(ThingWorxBootstrapper.java:132)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4710)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5135)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:714)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:917)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1701)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
*** CRITICAL ERROR ON STARTUP: Unable to initialize and start system: null
PS: I tried many TW versions: 5.1, 5.2, 5.4 - all with the same results.
Any idea of what could be happening?
paic
(To:emoreira)
One thought that comes to my mind is the fact that I've seen auto updates rolling out to Java 8, make sure your Tomcat is pointed to use the Java 7 jvm.
Beyond that, not sure what OS you are using, but since you are starting clean, I would try the following:
1. Stop tomcat
2. Remove tomcat/webapps/thingworx and the thingworx.war
3. Remove \ThingworxStorage and ThingworxBackupStorage
4. If you are on a Linux type environment, recreate the two Storage folders and make sure full permissions are granted on them.
Now start tomcat up and deploy Thingworx.
sm
(To:paic)
I just had the same issue yesterday. Was going in circles trying to figure out what it was until a friend asked me about the ThingWorx Storage and ThingWorx Backup Storage folders. I had installed and removed TWX a few months ago, and they were still on my machine. To correct the problem, I removed the WAR file and TWX app from Tomcat, rebooted and then removed all occurrences of ThingworxStorage and ThingworxBackupStorage. After redeploying the WAR, the application ran as expected.
emoreira
(To:emoreira)
Thanks guys.
I did the same think but without being so conscious: unisntalled everything that was related (including Java) and installed again.
savinash
(To:emoreira)
Hi @Ewerton Moreira,
I also faced same issue in Thingworx, How i get out of it, Please find below steps to troubleshoot.
     1) Check Thingworx folder have permitted Windows/Linux directory access.
     2) Validate Thingworx and Java both compatible version.
     3) Hope u have created folder "Thingworx Platform" placed platform-settings.json as per installation document.
     4) open platform-settings.json confirm that username and password
                "password": "twadmin",
                "username": "twadmin"
I had the same issue with Thingworx 5.4
In my case, I needed to move to Tomcat7 and Java7.
For Thingworx 6.x, Tomcat8 and Java8 are ok.
Thanks guys.
