Error Installing Thingworx Analytical Server
cnuga
11-Garnet
I am trying to reinstall Analytics Trial Edition 8.2 R3 after uninstalling it because of errors. I get the following message. All the ports required by ATE are free. Can't figure out what the error is.
5 REPLIES 5
cnuga
11-Garnet
(To:cnuga)
The following is the install log. Tried a few times, but couldn't reintstall
mgoel
(To:cnuga)
@cnuga
Thank you for opening this thread on community. Let me go through the logs and error, Will get back to you soon.
Regards-Mohit
mgoel
(To:mgoel)
Hi @cnuga
Could you please check the below article for the error.
https://www.ptc.com/en/support/article?n=CS290418
Follow this and do let me know if this helps.
Regards-Mohit
mgoel
(To:mgoel)
@cnuga
Did you get a chance to see this article. Please confirm.
cnuga
11-Garnet
(To:mgoel)
Haven't had a chance to implement the solution you mentioned. Will update once I do it.
