Error [authenticating connection], Server websocket will be closed. cause: Application Key not fou
laue
currently, I am using Thingworx 8.2, Analytics Extension 8.2, Thingpredictor 8.2.
When I start the Thingpredictor the follwing error is shown in the Error Log:
Error [authenticating connection], Server websocket will be closed. cause: Application Key not found
I checkt the correct app Key twice in both files(predictive-standalone.yml,system-environment-variable.properties) and even tried it without any app key by commenting the corresponding line out.
In the Thingpredictor cmd Window I can see the following:
ERROR [2018-11-20 09:15:51,723] com.thingworx.communications.client.connection.netty.ThingworxClientConnectionHandler: WebSocket error: com/thingworx/communications/client/connection/netty/ThingworxClientConnectionHandler$1, closing connection!
It is still possible to publish models. But it is not possible to trigger events or jobs via setting different parameters of a Thing in Thingworc Composer.
What could be the reason for this?
Cedrik
jgreiner
(To:laue)
Hi Cedrik,
I believe that I found the resolution to this issue in this article available here at the PTC Tech Support knowledge base.
Let me know if you have any further questions or concerns.
Warm Regards,
John
slangley
(To:jgreiner)
Hi @laue.
If the solution provided by @jgreiner helped to solve your issue, please mark it as the Accepted Solution for the benefit of others who may have the same question.
Regards.
--Sharon
