Error building extension : Could not find method compile() for arguments [directory 'twx-lib']
Velkumar
I'm trying to create custom extension. When I try to build extension using gradle I'm getting below error
> Could not find method compile() for arguments [directory 'twx-lib'] on object of type org.gradle.api.internal.artifacts.dsl.dependencies.DefaultDependencyHandler.
Gradle Version : 7.1.1
Java Version : JDK 11
Could any one help me to solve this issue
VR
TonyZhang
(To:Velkumar)
Hi @Velkumar,
Try using an older Gradle Version prior to 6.9 like 6.9.1, 6.8.3... to see if it resolves the issue.
Tony
TonyZhang
(To:Velkumar)
Hi @Velkumar,
Tony
Velkumar
(To:TonyZhang)
Thanks @TonyZhang
It works with Gradle 6.9.1 with JDK 11
Maybe verify that the Gradle Java home is pointing to a Java SDK.
