Error deleting from thingworx
xotzHelper
11-Garnet
Hi, i'm using thingworx 8.5.5 and i cannot delete anything from it. I get the following error:
Thank you !
3 REPLIES 3
mgoel
(To:xotzHelper)
@xotzHelper
Thanks for opening this post. Could you please check what is the error message in the logs.
Mohit
Hi @mgoel  !
It doesn't appear any errors in application logs or script logs.
slangley
23-Emerald II
(To:xotzHelper)
Hi @xotzHelper.
I recommend that a case be opened for this issue.  I will be happy to open one on your behalf if you agree.
--Sharon
