Error during Thingworx.war deploy on tomcat
mmedeiros
6-Contributor
I get a Error during Thingworx.war deploy on tomcat
GRAVE [http-nio-8080-exec-9] org.apache.catalina.core.ApplicationContext.log HTMLManager: FAIL - Deploy Upload Failed, Exception: org.apache.tomcat.util.http.fileupload.FileUploadBase$SizeLimitExceededException: the request was rejected because its size (93796698) exceeds the configured maximum (52428800)
does anyone know a solution?
Best Regards
Mônica
posipova
20-Turquoise
(To:mmedeiros)
How do you deploy the war file, through web browser or manually?
I would recommend manually copying the thingworx.war inside the <tomcat installation folder>webapps directory while the tomcat service is stopped.
Example: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps
posipova
20-Turquoise
(To:mmedeiros)
posipova
20-Turquoise
(To:posipova)
Follow up, you may also change maxPostSize in the http server tomcat connector located in /conf/server.xml as follows:
<Connector connectionTimeout="20000" port="8080" protocol="HTTP/1.1" redirectPort="8443" maxPostSize="104857600"/>
Set maxPostSize to 104857600 increase the upload file size to 100 Mo. By default it's set to 2 Mo.
For more explanation, read this : https://tomcat.apache.org/tomcat-7.0-doc/config/http.html
mmedeiros
6-Contributor
(To:posipova)
Thank you a lot!
Worked after the manualy deploy
posipova
20-Turquoise
(To:mmedeiros)
Great to hear! Could you please mark the response that helped as correct? That would help improve the searchability of our community.
