Error executing service
pa2t
6-Contributor
what is this error?
service gets a string as input.. some strings works.  Checked logs but only displays error name. Please help
For sure you have an error on your script, if you share here we may detect the error. You are trying to access an array out of it's length.
pa2t
6-Contributor
(To:pa2t)
pa2t
6-Contributor
(To:CarlesColl)
thanks for the response, I did look into the data source and it did not have any data for the particular attribute that i was looking for. thank you
