Error - import Source control entities / TWX 8.4. to 9.1
mvajla
Hi all,
during importing SourceControlEntities I got following errors.
This is only happening when I am importing complete .zip file, but when I unzip this and import entities as a single file, it works fine.
Importing the same "project" to the version 8.4.x. is without errors.
Is there any possible solution how to import SourceControlEntities from older version to the 9.x?
Unable to Invoke Service ImportSourceControlledEntities on SourceControlFunctions : null
ErrorCode(cdeb5a8e-1660-4035-97fd-12e3db90e19f), Cause(null), Reason(Access was attempted on a null reference variable.), Possible Resolutions(Remove the reference to the null variable within your extension code.)
mvajla
(To:kazunari)
I didn't realise that I need to unzip a .zip file before import.
So case is solved.
kazunari
(To:mvajla)
Hi, check visibility and permission on entity "SourceControlFunctions" and add Visibility permission to the Entity for the Unit or Organization of the users.
mvajla
(To:kazunari)
So case is solved.
