Error importing: Unable To Convert From...
csantos
Hi, After installing ThingWorx 8.2.5-b260 I started the "Introduction to ThingWorx 8" course. In "part 1" there is an exercise for importing external contents from the course materials. When I try to import the xml entities I get the error "Error importing: error, Not Acceptable". In the attachment is my application log. Can someone help? TY
Hi @csantos,
You need to unzip the downloaded Lab files and import json and xml seperately.
Himanshu
csantos
(To:hchanana)
@hchanana wrote:
Hi @csantos,
Himanshu
Hi @hchanana,
I've tried your solution and I get the same error when importing the "Creating a Project.xml". As for the widgets, they were already installed.
Thank you
