Error in updating values from Java Client
vranganathan
I have written Java client subclassing VirtualThing similar to SteamThing and SteamSensorClient. I am updating five different values. Only three of them getting updated. I am seeing the following error in the client console. Any help will be greatly appreciated.
Thanks in advance.
09:49:38.755 DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
DE001 - Position: 0.8559873665751253
DE001 - Speed: 28
DE001 - CurrentFuelTemperature: 24
DE001 - MAP Voltage: 1.7187178145076012
DE001 - Oxygen Voltage: 0.04258031328471801
09:49:38.920 DEBUG c.t.c.c.e.CommunicationEndpoint - Sending synchronous message, waiting for response [sync key: 44, message: APIRequestMessage requestId: 44, endpointId: 0, sessionId: 6, method: POST, entityName: *DE001, characteristic: Services, target: UpdateSubscribedPropertyValues]
09:49:38.921 DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=361
09:49:38.924 DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
09:49:38.924 DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=187
09:49:38.925 DEBUG c.t.c.c.e.DispatchingClientEndpoint - RESPONSE received endpoint id: 0, duration: 4 ResponseMessage requestId: 44, endpointId: 0, sessionId: -1, code: STATUS_SUCCESS, multipart: false, packet #: 0, total packets: 0
09:49:38.925 ERROR c.t.c.client.things.VirtualThing - Unable To Update Subscribed Properties For DieselEngine001 : Unable to dispatch : Unable to Invoke Service UpdateSubscribedPropertyValues on DieselEngine001 : null</p></font>
Are you sure you are making at least one call to setProperty(propertyname, PropertyValue) for each of the properties?
Yes. It worked on some properties and did not work two of the properties.
