This is the output from Wsems
pi@raspberrypi:~/microserver $ sudo ./wsems
[INFO ] 2017-08-11 16:49:23,571 ./wsems: Using config file: /home/pi/microserver/etc/config.json
[FORCE] 2017-08-11 16:49:23,571 ./wsems: Starting up ....
[FORCE] 2017-08-11 16:49:23,572 ./wsems: Initializing EMS ....
[FORCE] 2017-08-11 16:49:23,572 main: Using config file /home/pi/microserver/etc/config.json
[INFO ] 2017-08-11 16:49:23,572 ./wsems: Creating the WsEms proxy.
[INFO ] 2017-08-11 16:49:23,572 ./wsems: Starting HTTP Server.
[INFO ] 2017-08-11 16:49:23,573 ./wsems: Initializing the ThingWorx REST interface.
[FORCE] 2017-08-11 16:49:23,573 httpServer: starting http server port=8088
[DEBUG] 2017-08-11 16:49:23,573 httpServer: http server bound to port=8088.
[DEBUG] 2017-08-11 16:49:23,574 SDK: twWs_Create: Initializing Websocket Client for 54.64.229.7:80//Thingworx/WS
[DEBUG] 2017-08-11 16:49:23,574 SDK: twTlsClient_Create: Initializing TLS Client
[DEBUG] 2017-08-11 16:49:23,575 SDK: twApi_Initialize: Websocket Established after 0 tries
[DEBUG] 2017-08-11 16:49:23,575 SDK: subscribedPropsMgr_Initialize: Initializing subscribed properties manager
[DEBUG] 2017-08-11 16:49:23,575 jsonConfigurator::getJsonEntity: Key cert_chain not found
[DEBUG] 2017-08-11 16:49:23,575 jsonConfigurator::getJsonEntity: Key validation_criteria not found
[DEBUG] 2017-08-11 16:49:23,576 jsonConfigurator::getJsonEntity: Parent file not found
[DEBUG] 2017-08-11 16:49:23,577 SDK: twTunnelManager_Create: Tunnel Manager singleton already exists
[DEBUG] 2017-08-11 16:49:23,576 WsEmsProxy::bindThing: Host specified as 'localhost'. Testing IPV6/IPV4 connectivity
[DEBUG] 2017-08-11 16:49:23,578 SDK: added PiThing to boundList
[DEBUG] 2017-08-11 16:49:23,578 SDK: twApi_BindThings: not currently connected, only binding things to api
[DEBUG] 2017-08-11 16:49:23,578 SDK: twMessage_Delete: Deleting BIND Message: 1
[DEBUG] 2017-08-11 16:49:23,578 jsonConfigurator::getJsonEntity: Parent file not found
[INFO ] 2017-08-11 16:49:23,578 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2017-08-11 16:49:23,579 ./wsems: Starting the connection.
54.64.229.7:80-->[DEBUG] 2017-08-11 16:49:23,580 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-08-11 16:49:23,581 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2017-08-11 16:49:23,956 SDK: ws_on_headers_complete: Websocket connected!
[INFO ] 2017-08-11 16:49:23,956 SDK: twWs_Connect: Websocket connected!
[DEBUG] 2017-08-11 16:49:23,956 SDK: twWs_SendMessage: Sent 60 bytes using 1 frames.
[DEBUG] 2017-08-11 16:49:24,334 SDK: twMessage_Delete: Deleting RESPONSE Message: 2
[DEBUG] 2017-08-11 16:49:24,334 SDK: twMessage_Delete: Deleting AUTH Message: 2
[WARN ] 2017-08-11 16:49:24,335 SDK: twBindBody_Delete: NULL body or stream pointer
[DEBUG] 2017-08-11 16:49:24,335 SDK: twMessage_Delete: Deleting BIND Message: 0
[DEBUG] 2017-08-11 16:49:24,335 SDK: twWs_SendMessage: Sent 26 bytes using 1 frames.
[DEBUG] 2017-08-11 16:49:24,337 SDK: sendCtlFrame: >>>>> Sending Ping. Msg: 11:19:24
[INFO ] 2017-08-11 16:49:24,381 Main: Succesfully connected. Saving .booted config file
[DEBUG] 2017-08-11 16:49:24,784 SDK: twMessage_Delete: Deleting RESPONSE Message: 3
[DEBUG] 2017-08-11 16:49:24,784 SDK: twMessage_Delete: Deleting BIND Message: 3
[DEBUG] 2017-08-11 16:49:25,792 SDK: twTlsClient_Create: Initializing TLS Client
[DEBUG] 2017-08-11 16:49:25,795 TlsStream::doclose: Disconeccting socket
[DEBUG] 2017-08-11 16:49:25,795 SDK: twTlsClient_Close: Disconnecting from server
[DEBUG] 2017-08-11 16:49:25,795 emsRequestHandler: Got 405 response code from POST request on Things/PiThing/Services/NotifyPropertyUpdate
[DEBUG] 2017-08-11 16:49:25,796 SDK: twTlsClient_Close: Disconnecting from server
[WARN ] 2017-08-11 16:49:25,796 SDK: InfoTable precheck: Name not found in datashape
[DEBUG] 2017-08-11 16:49:25,797 SDK: twMessage_Delete: Deleting RESPONSE Message: 0
[DEBUG] 2017-08-11 16:49:25,896 SDK: twWs_SendMessage: Sent 402 bytes using 1 frames.
[DEBUG] 2017-08-11 16:49:25,896 SDK: twMessage_Delete: Deleting RESPONSE Message: 13
[DEBUG] 2017-08-11 16:49:25,896 SDK: twMessage_Delete: Deleting REQUEST Message: 13
this is the output from lua script
pi@raspberrypi:~/microserver $ sudo ./luaScriptResource
[INFO ] 2017-08-11 17:22:33,152 ./luaScriptResource: Using config file: /home/pi/microserver/etc/config.lua
[FORCE] 2017-08-11 17:22:33,153 ./luaScriptResource: Starting up ....
[INFO ] 2017-08-11 17:22:33,160 ./luaScriptResource: New path is /home/pi/microserver/etc/thingworx/clibs:/home/pi/microserver/etc/custom/clibs:/home/pi/microserver/etc/community/clibs:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
[INFO ] 2017-08-11 17:22:33,220 thingworx.shape: Creating a new shape.
[INFO ] 2017-08-11 17:22:33,221 PiThing: -- Configuration -------------------------------
[INFO ] 2017-08-11 17:22:33,221 PiThing: scanRate: 60000
[INFO ] 2017-08-11 17:22:33,221 PiThing: scanRateResolution: 500
[INFO ] 2017-08-11 17:22:33,221 PiThing: taskRate: 15000
[INFO ] 2017-08-11 17:22:33,221 PiThing: keepAliveRate: 60000
[INFO ] 2017-08-11 17:22:33,221 PiThing: requestTimeout: 15000
[INFO ] 2017-08-11 17:22:33,221 PiThing: registerRate: 43200000
[INFO ] 2017-08-11 17:22:33,221 PiThing: register: true
[INFO ] 2017-08-11 17:22:33,221 PiThing: getPropertySubscriptionOnReconnect: false
[INFO ] 2017-08-11 17:22:33,221 PiThing: maxConcurrentPropertyUpdates: 100
[INFO ] 2017-08-11 17:22:33,222 PiThing: defaultPushType: VALUE
[INFO ] 2017-08-11 17:22:33,222 PiThing: useShapes: true
[INFO ] 2017-08-11 17:22:33,222 PiThing: identifier: Not Specififed
[INFO ] 2017-08-11 17:22:33,222 PiThing: ------------------------------------------------
[INFO ] 2017-08-11 17:22:33,223 thingworx.template: Adding shape 'shapes.metadata' to template 'thingworx.template'
[INFO ] 2017-08-11 17:22:33,224 thingworx.template: Adding shape 'shapes.propsubscribe' to template 'thingworx.template'
[INFO ] 2017-08-11 17:22:33,229 thingworx.template: Creating new templates.PiTemplate named 'PiThing'
[INFO ] 2017-08-11 17:22:33,229 PiThing: -- Initializing properties ---------------------
[INFO ] 2017-08-11 17:22:33,230 PiThing: Initialized property upToDate [baseType: BOOLEAN, pushType: NEVER, handler: nil, value: true]
[INFO ] 2017-08-11 17:22:33,230 PiThing: Initialized property cpu_volt [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2017-08-11 17:22:33,230 PiThing: Initialized property cpu_temperature [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[FORCE] 2017-08-11 17:22:33,231 httpServer: starting http server port=8001
[INFO ] 2017-08-11 17:22:33,231 PiThing: Initialized property cpu_freq [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2017-08-11 17:22:33,231 PiThing: ------------------------------------------------
[INFO ] 2017-08-11 17:22:36,202 PiThing: -- Starting script --------------------------
[INFO ] 2017-08-11 17:22:36,202 PiThing: Registering core callback handler
[INFO ] 2017-08-11 17:22:36,203 PiThing: Starting main loop
[INFO ] 2017-08-11 17:22:36,203 PiThing: Calling lifecycle start listeners.
[INFO ] 2017-08-11 17:22:36,203 shapes.propsubscribe: Initialized
[INFO ] 2017-08-11 17:22:36,204 thingworx.handler: Creating a new handler.
[INFO ] 2017-08-11 17:22:36,213 PiThing: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2017-08-11 17:22:36,229 PiThing: MicroServer is now available.
[INFO ] 2017-08-11 17:22:36,229 PiThing: EMS is available: true, online: false
[INFO ] 2017-08-11 17:22:42,268 PiThing: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2017-08-11 17:22:42,274 PiThing: EMS is available: true, online: false
[INFO ] 2017-08-11 17:22:48,281 PiThing: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2017-08-11 17:22:48,285 PiThing: EMS is available: true, online: false
[INFO ] 2017-08-11 17:22:54,309 PiThing: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2017-08-11 17:22:54,314 PiThing: EMS is available: true, online: false
[INFO ] 2017-08-11 17:23:00,324 PiThing: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2017-08-11 17:23:00,329 PiThing: EMS is available: true, online: false
But i am not able to connect Server and not able to connect ems
and i am not able to see property in Pi thing in remote under managing property binding
pls help me to solve this issue
Hi Shruti,
It sounds like you're using an auto_bind configuration in the EMS, which is not something you need to do if you're running the LSR. Try removing the 'auto_bind' structure from config.json and see if that fixes the issue.
Hi Alex,
After removing the auto_bind from config.json file, still the same error is coming
Hi ,
Is your ems and thingworx connecting and binding the data to thingworx
Please help me with that I am getting the same error
Is this error resolved.
