Error on create Thing
mmancin
Hi all, I've installed TW9.1.0 and I try to create new thing into service with this script:
var params = {
thingTemplateName: "GenericThing"
Resources["EntityServices"].CreateThing(params);
Things["NewThingName"].Enable();
Things["NewThingName"].Restart();
But always give this error:
Error executing service AA. Message :: TypeError: Cannot find function Enable in object com.thingworx.things.ConfiguredThing@20a84ab1. - See Script Error Log for more details.
what am I doing wrong?
mgoel
(To:mmancin)
@mmancin
Check this if it works or not.
Things['abc'].EnableThing();
Things['abc'].RestartThing();
Mohit
5 REPLIES 5
mgoel
(To:mmancin)
@mmancin
Thanks for opening this post on community. I tried with below code and its working.
let params = {
name: 'abc' /* STRING */,
description: 'xyz' /* STRING */,
thingTemplateName: 'GenericThing' /* THINGTEMPLATENAME */,
projectName:'PTCDefaultProject' /* PROJECTNAME */,
//tags: undefined /* TAGS */
// no return
Mohit
mmancin
(To:mgoel)
@mgoel
Have you try to Enable and Restart Thing?
Things["abc"].Enable();
Things["abc"].Restart();
I received always the same message
Error executing service aa. Message :: TypeError: Cannot find function Enable in object com.thingworx.things.ConfiguredThing@96aeb2a. - See Script Error Log for more details.
mgoel
(To:mmancin)
@mmancin
Mohit
mmancin
(To:mgoel)
@mgoel now it works! Thanks.
I follow this guide
https://community.ptc.com/t5/IoT-Tech-Tips/Creating-a-Thing-in-Service-Script/td-p/533427
but I see it's wrong (or maybe it's just to update)
mgoel
(To:mmancin)
@mmancin
Welcome, Could you please mark my answer accept as solution for the benefit of other community users. It will be helpful.
Mohit
