The message you are trying to access is permanently deleted.
Hello everyone,
I've noticed that on the Bar Chart widget, it's not possible to format the xAxis format. In my case I'm using a DATETIME for the xAxis and I would like to display it as ('MM:dd') and by default this is applied as ('yyyy-MM-dd'). (See image in attachment).
Are there any workarounds for this matter? I'm using ThingWorx v9.1
Best regards,
Hi @rnfonseca , You can modify the service code mentioned in below link to get only dd:MM format.
Hello @anarwal ,
The code you provided is for the Label Chart (not sure if it's applicable to Bar Chart widgets). And it works around the issue. It casts the DATETIME to a STRING value and formats it. If I wanted to I could have created a datashape with a Date under a STRING format, and passed it to the Bar Chart. I was asking for a cleaner way to do it.
Hello @cdias,
Have you tried using the Schedule Chart Widget. You can define the xAxis format by changing the TimeAxisDateFormatToken using MM-dd.
Hope it helps,
