Error to import New Dataset on analystics builder
psoares
When I am trying to import a new dataset  I am getting the error message "ERROR: column "c7" specified more than once",  but there is nothing with the same value in any place.
What can cause this error?
3 REPLIES 3
cmorfin
(To:psoares)
Hi
Is it possible for you to upload the dataset.csv file and the configuration json file ?
We would need that to investigate.
Thank you
Kind regards
Christophe
psoares
(To:cmorfin)
Follow the file below.
Zip.zip - Google Drive
cmorfin
(To:psoares)
Hi
Thank you for that.
The field Weight_Rate_Filling_Silo1 is defined twice int he json file and there are 2 columns with this name in the csv.
I am guessing this is a typo and you meant to have Weight_Rate_Filling_Silo1 and Weight_Rate_Filling_Silo2.
In any case the field name should be unique.
I can successfully create the dataset when using Weight_Rate_Filling_Silo1 and Weight_Rate_Filling_Silo2.
Could you try with this modification and see if that works also for you ?
Thank you
Kind regards
Christophe
