Error while calling REST service
pmishra-4
I am getting error while calling thing service . While its working fine for locally deployed service . I am getting below error
Wrapped java.net.UnknownHostException: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server (dev1.tcupiot.com) Cause: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server (dev1.tcupiot.com)
The service i am trying is :-
var params1 = {
proxyScheme: undefined /* STRING */,
headers:{
  "Accept": "*/*",
  "tenantId": "12345"
ignoreSSLErrors: true /* BOOLEAN */,
useNTLM: undefined /* BOOLEAN */,
workstation: undefined /* STRING */,
useProxy: undefined /* BOOLEAN */,
withCookies: undefined /* BOOLEAN */,
    url:"http://xxxx.com/app/user5/XXXservice/Alert/Query?eventDateTime=YYYY-MM-dd" /* STRING */,
    //url:"http://localhost:8081/XXXXservice/Alert/Query?eventDateTime=2016-06-12%2C2018-10-15",
    timeout: undefined /* NUMBER */,
proxyPort: undefined /* INTEGER */,
password: undefined /* STRING */,
username: undefined /* STRING */
// result: JSON
var data = Resources["ContentLoaderFunctions"].GetJSON(params1);
var params2 = {
infoTableName: "alertTable" /* STRING */,
dataShapeName: "AlertDataShape" /* DATASHAPENAME */
var jsonTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params2);
for(var i=0;i<data.array.length;i++)
jsonTable.AddRow({vehicleRegNo:data.array.vehicleRegNo,
                  eventTypeName:data.array.eventTypeName,
                  eventLocDescription:data.array.eventLocDescription,
                 eventDatetime:data.array.eventDatetime,
                  speed:data.array.speed,
                  description:data.array.description
result = jsonTable;
jamesm1
(To:pmishra-4)
This looks like a DNS error to me -- have you tried using a fully qualified domain name? Does it respond to a ping from the TWX server? Are the DNS settings correct?
