I am trying to create Cassandra DB Thing but it is not getting connected and shows below error in logs,
"ERROR starting: JDBC Driver Class Not Found: org.apache.cassandra.cql.jdbc.CassandraDriver".
I have created Cassandra persistence provider and even Cassandra DB is installed and running fine on server.
Please advise.
Anita
Just to verify, you installed the Cassandra DB extension?
Hi PaiChung
You are right, i don't have Cassandra DB extension and not able to find it on Marketplace.
Please help me with the link or extension.
I believe this is not on the marketplace and I believe you need to specifically request this.
What is your use case that you would need Cassandra?
