I have recently installed Thingworx on my local machine, I am getting error when I am creating any new entity and saving it.
Error on Thingworx Composer :
auto;"> <div class="widget-content widget-image undefined" id="error_Image-1"> <img src="/Thingworx/images/ThingworxLogo.png" alt="Errors"/> </div> </div> <div id="error_Panel-1"> <p>500 Unexpected Error - Contact your system administrator for more details</p> <a href="/Thingworx" onclick='clickAndDisable(this);'>Back to Composer</a> </div> </body> </html>
Error in Application Logs :
[L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ???] [S: ] [P: ] [T: http-nio-8080-exec-8] org/apache/tomcat/util/http/Parameters$FailReason
Error in Error Logs :
[L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: ???] [S: ] [P: ] [T: http-nio-8080-exec-9] org/apache/tomcat/util/http/Parameters$FailReason
Thingworx Details are as under :
Version : ThingWorx 8.5.14-b854
Kindly, help me troubleshoot this error. Attaching screenshot of composer error for reference.
Siddharth
Hi Constantine,
Thanks for your quick reply. I have used Thingworx Installer. I tried restarting my tomcat and now I am not facing this issue.
Siddharth
Hello Siddharth,
This looks like some issue with your Tomcat installation. Did you use ThingWorx Installer or just dropped the WAR file into your Tomcat webapps folder? If you did the latter, I would suggest doing a fresh Tomcat install using an official Tomcat installer version 8.5.66 or 9.0.46, then retry. If you used ThingWorx Installer, then I can't help much, except for recommending to use a more recent ThingWorx version.
/ Constantine
Hi Constantine,
Siddharth
