Hi all,
I'm getting this error when I am importing Gantt chart widget extension -
ERROR [widget] "CustomCSS" widget type is missing required member widgetProperties()
I'm attaching the widget zip file for reference. Any help would be much appreciated.
There was a similar error before - "Progress gauge import failed in TWX 9.1.0": https://community.ptc.com/t5/ThingWorx-Developers/Progress-gauge-import-failed-in-TWX-9-1-0/td-p/735220
Hi @VladimirN ,
The extension already have a metadata.xml file. The file is automatically generated so I don't think that is the issue.
Thanks for the help anyway.
Hi @FJ_10364026,
Even I can successfully import the extension you attached to ThingWorx, I cannot enter and edit the sample mashup somehow.
I found below extension GanttChart-min-1.0.2.zip (It seems not working with newer ThingWorx versions 9.1.x ~ 9.3.x)
https://github.com/ptc-iot-sharing/GanttChartWidgetWidgetTWX/releases/tag/1.0.2
I imported it to 8.5.x along with the sample entities from https://github.com/ptc-iot-sharing/GanttChartWidgetWidgetTWX/blob/frappe/docs/sample_entities.xml
Open the Test_GanttChartData mashup, click Yes to replace deprecated widgets,
then View Mashup, I can see the Gantt Chart displays successfully.
Make sure below settings are all set to true in platform-settings.json before importing extensions.
"ExtensionPackageImportPolicy": {
"importEnabled": true,
"allowJarResources": true,
"allowJavascriptResources": true,
"allowCSSResources": true,
"allowJSONResources": true,
"allowWebAppResources": true,
"allowEntities": true,
"allowExtensibleEntities": true
