Error while installing Thingworx foundation 90 days trial
DT_9697337
Hi
I'm not able to install thingworx 9.0 version 90days trail fro windows , facing below error,
I have attached environment variable image and all log file please suggest where I was wrong.
I have reinstall my system OS  it is now working and successfully installed, But I thing this is not right way to clean your OS and reinstall again while facing such Thingworx installation issue.
It must have another way to install without doing unistalled your system OS.
8 REPLIES 8
slangley
23-Emerald II
(To:DT_9697337)
Hi @DT_9697337.
Here are some things to check:
  • You need to put JAVA_HOME under System environment variables
  • Do you have multiple version of Java installed?  I see this on line 18 of the bitrock installer log:
[16:16:39] - HOST_JAVA_HOME path: C:\PROGRA~1\Java\JDK18~1.0_2\jre...
  • Are you running the installer as Administrator?
Please let us know if you continue to have issues.
--Sharon
  • You need to put JAVA_HOME under System environment variablesI did this oath and tried but it gives me same error
  • Do you have multiple version of Java installed?  I see this on line 18 of the bitrock installer log:I dont have more java installed on my system, only one i have installed jdk 1.8.0_251, Also i have attached my environment variable setting image please check.
  • Are you running the installer as Administrator?Yes, I tried with run as Administrator but it gives me same error.
Please suggest me the right way i'm trying from last 4 days.
Anyone here for help how to solve this problem,I am facing this error.
Yes, I tried with run as Administrator but it gives me same error. Please suggest me the right way i'm trying from last 4 days.
slangley
23-Emerald II
(To:slangley)
Hi @DT_9697337.
I'm wondering if it is because you have path statements to both the JRE\bin and JDK\bin.  Try removing the JDK\bin and try again.
Also, which version of Windows are you installing on?  Are you following these instructions?
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @DT_9697337.
We're sorry to hear about your installation issues.  We are constantly striving to make improvements so if you can provide some specifics regarding the issues you encountered that led to reinstalling the O/S, I will be happy to follow up with R&D.
--Sharon
slangley
23-Emerald II
(To:slangley)
For the sake of other community members experiencing issues, please be advised that trial versions of the product are limited to either 90 or 30 days depending on whether it is installed locally or in the cloud.  This trial period is to allow for an assessment of the product only.  If there is a need to go beyond the time indicated, the Sales team should be contacted.  They can assist with an extension if it is warranted.
Note that installation of a trial version locally, and then reinstallation of the trial in an attempt to extend the trial period, is prohibited and the software will block subsequent installation attempts.  Sales can override this (again, if warranted) by providing an extended license.  There is no need to reinstall the product.
--Sharon
Yes i agree, I was install thingworx 9.0 90days then when it has excited i
have reinstalled thingworx 9.0 again it was successful installation
But when I was installed 3rd installation after expired 2nd thingworx 9.0
90days it is giving me this error i'm not able to install this version
where i was wrong ghara my question.
You are telling me
