Error with Raspberry Pi
  • November 29, 2015
  • 3 replies
  • 4340 views
I am getting the upgrade error with the twc_agent executable when I try to run in Raspberry Pi. Has some one fixed it and be able to run it, any suggestions/help?
    Best answer by Aanjan
    The appKey comes from the server/ platform you are trying to connect to. Unless this is a prepackaged installation with the server information pre-configured, you would need to create a new appKey on the platform and then copy it over.
    Hi Maniappan,
    It is good if you can show us the error messages in your Rasp Pi.
    mr11-VisitorAuthor
    Here is the log I get on running twc_agent :
    [ERROR] 2015-11-29 17:48:09,813: ws_on_header_value: Invalid 'connection' header: Upgrade
    [ERROR] 2015-11-29 17:48:09,814: ws_on_headers_complete: Websocket connection failed
    [ERROR] 2015-11-29 17:48:09,815: twWs_Connect: Error trying to connect
    This is coming periodically when it tries to connect.
    It seems like the Thingworx server is not connected. Have you modified the main.c file to change the Host name and Appkey? The file is located at home/pi/tw-c-sdk/examples/SteamSensor/src.
    mr11-VisitorAuthor
    Hi Peng,
    Thanks for the reply. The documentation here at Raspberry Pi with ThingWorx C SDK | ThingWorx didn't ask me to change anything, so ran as is. If these steps are not proper do let me know proper one.
    mr11-VisitorAuthor
    There is no configuration that I am able to do in main.c. The configuration was found in agent.properties file that is loaded when twc_agent is run. I have changed the Appkey and started it, host is pointing to the the device.cloud.thingworx.com site. I enabled DEBUG and I am getting this after the GPIO are registered. Please let know if there is some other issue here!
    Maniappan.
    [DEBUG] 2015-12-06 14:01:35,608: twTlsClient_Reconnect: Re-establishing SSL context
    [DEBUG] 2015-12-06 14:01:35,829: twTlsClient_Connect: Connecting to server
    [DEBUG] 2015-12-06 14:01:35,833: twTlsClient_Connect: TLS connection established
    [TRACE] 2015-12-06 14:01:35,834: twWs_Connect: Connected to device.cloud.thingworx.com:80
    [TRACE] 2015-12-06 14:01:35,834: twWs_Connect: Sent request:
    GET /Thingworx/WS HTTP/1.1
    User-Agent: ThingWorx C SDK
    Upgrade: websocket
    Connection: Upgrade
    Host: device.cloud.thingworx.com
    Sec-WebSocket-Version: 13
    Sec-WebSocket-Key: YDbFo5YONb2bWzgAXk0+gA==
    Max-Frame-Size: 8192
    applicationKey: a7fdd7ab-d3ce-4313-ab93-6226ed9b7ef4
    [DEBUG] 2015-12-06 14:01:36,392: HTTP Response begun
    [TRACE] 2015-12-06 14:01:36,392: Header->server : Apache-Coyote/1.1
    [TRACE] 2015-12-06 14:01:36,393: Header->sec-websocket-accept : j0V2dHwjmWVeJCikwBpXtBLXG4U=
    [TRACE] 2015-12-06 14:01:36,393: Header->date : Sun, 06 Dec 2015 08:31:36 GMT
    [TRACE] 2015-12-06 14:01:36,393: Header->connection : Upgrade
    [ERROR] 2015-12-06 14:01:36,393: ws_on_header_value: Invalid 'connection' header: Upgrade
    [TRACE] 2015-12-06 14:01:36,393: Header->upgrade : websocket
    [ERROR] 2015-12-06 14:01:36,393: ws_on_headers_complete: Websocket connection failed
    [TRACE] 2015-12-06 14:01:36,393: twWs_Connect: Parsed 193 bytes out of 193
    [ERROR] 2015-12-06 14:01:36,393: twWs_Connect: Error trying to connect
    [DEBUG] 2015-12-06 14:01:36,393: twTlsClient_Reconnect: Re-establishing SSL context
    [DEBUG] 2015-12-06 14:01:36,610: twTlsClient_Connect: Connecting to server
    [DEBUG] 2015-12-06 14:01:36,613: twTlsClient_Connect: TLS connection established
    [DEBUG] 2015-12-06 14:01:41,614: twTlsClient_Reconnect: Re-establishing SSL context
    [DEBUG] 2015-12-06 14:01:41,835: twTlsClient_Connect: Connecting to server
    [DEBUG] 2015-12-06 14:01:41,840: twTlsClient_Connect: TLS connection established
    [TRACE] 2015-12-06 14:01:41,841: twWs_Connect: Connected to device.cloud.thingworx.com:80
    [TRACE] 2015-12-06 14:01:41,841: twWs_Connect: Sent request:
    Upgrade: websocket
    Connection: Upgrade
    Sec-WebSocket-Key: S7iOiIovHM0yx7USJvAm1w==
    [DEBUG] 2015-12-06 14:01:42,367: HTTP Response begun
    [TRACE] 2015-12-06 14:01:42,367: Header->server : Apache-Coyote/1.1
    [TRACE] 2015-12-06 14:01:42,367: Header->sec-websocket-accept : 6QHmcIelri4vVUUMWNlv0fLhgB0=
    [TRACE] 2015-12-06 14:01:42,367: Header->date : Sun, 06 Dec 2015 08:31:42 GMT
    [TRACE] 2015-12-06 14:01:42,367: Header->connection : Upgrade
    [ERROR] 2015-12-06 14:01:42,367: ws_on_header_value: Invalid 'connection' header: Upgrade
    [TRACE] 2015-12-06 14:01:42,368: Header->upgrade : websocket
    [ERROR] 2015-12-06 14:01:42,368: ws_on_headers_complete: Websocket connection failed
    [TRACE] 2015-12-06 14:01:42,368: twWs_Connect: Parsed 193 bytes out of 193
    [ERROR] 2015-12-06 14:01:42,368: twWs_Connect: Error trying to connect
    [DEBUG] 2015-12-06 14:01:42,368: twTlsClient_Reconnect: Re-establishing SSL context
    [DEBUG] 2015-12-06 14:01:42,592: twTlsClient_Connect: Connecting to server
    [DEBUG] 2015-12-06 14:01:42,602: twTlsClient_Connect: TLS connection established
    [DEBUG] 2015-12-06 14:01:47,603: twTlsClient_Reconnect: Re-establishing SSL context
    [DEBUG] 2015-12-06 14:01:47,834: twTlsClient_Connect: Connecting to server
    [DEBUG] 2015-12-06 14:01:47,837: twTlsClient_Connect: TLS connection established
    Maniappan, Alternatively, if you are not trying to connect over SSL you are going to want to include the following function call before the connection is made in the main function in main.c: twApi_DisableEncryption();
    mr11-VisitorAuthor
    Thanks to all who replied, I got it up and running yesterday. There were couple of issues, my provider is having reverse proxy, had to try with someone else. While playing around with configuration I had modified the original key and resetting back it worked.
    Now to get to do some actual data generation..
