Error with simple Master template display of header and footer
jwilson-2
I have recently upgraded to 7.2.3 Framework and the basic header / footer master template does not appear to be working.  The footer content is being displayed at the top of the page.  I am attaching a PDF document with the presentation seen as well as the master export.  Nothing other than two labels each on a panel in the header and footer.  I tried this in both Chrome and IE to see if there was a browser specific issue.  Am I doing something wrong in 7.2.3 that changed from 7.1 or is this an issue with the new version?
3 REPLIES 3
ttielebein
(To:jwilson-2)
Hello, this appears to be a bug. I have just opened Jira PSPT-2952 for this and will create a KCS article documenting this as well. Thanks for bringing this to our attention. I'll let you know of any updates.
Thanks!
Tori
I've already opened a case about it too: 13292666 Tori can you inform to Michael Neumann about it as he didn't said nothing about the jira bug opened.
This bug makes 7.2.3 totally unusable.
ttielebein
(To:jwilson-2)
Hello, the bug defect is marked as resolved. The fix should be released in 7.3.0 and 7.2.4, the latter of which should be out any day now.
