Event Chart
Saranya_S
11-Garnet
Event Chart
         I've the requirement like, in event chart its shows both start and end time which is able to bind.Attached screen shots for reference.In that screen shot it shows only start time but we need to end time also.
If I have understood your requirement correctly, you could probably achieve this using a Schedule Chart available in ThingWorx 9.0.
Let me know one thing, can i import and use schedule chart widget in ThingWorx 8.4.
CharlesJi
(To:Saranya_S)
Hi @Saranya_S, no, I believe Schedule Chart is a new feature since ThingWorx 9.0.
slangley
(To:Saranya_S)
Hi @Saranya_S.
If you feel your question has been answered, please mark the appropriate post as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
