Event and mail generation
adityak506
Hi All,
I have two properties A and B, now I want to generate an event when property A value is less than B value. Also I need to send an email when this condition happens. How I can achieve this? I am using ThingWorx 8.3 version.
PaiChung
22-Sapphire I
(To:adityak506)
You can do this by using the DataChange event.
You'd have to probably monitor the change in both the A and B values.
Also please be aware, if these values change often, then you might be sending a lot of notifications.
So you might want to either create some logic to prevent that, or resolve this into a Boolean Property that you set to True or False this way you can provide a 'lock in' and then send notification on the true/false toggle
3 REPLIES 3
PaiChung
22-Sapphire I
(To:adityak506)
Thank you for the reply
slangley
(To:PaiChung)
Hi @adityak506.
If you are satisfied with the response provided by @PaiChung, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
